Threads: 82
27
Ideally a varied range would be good, 30mm, 40-45mm, 50, 60mm etc..
Thinking about lowering the HDi some more but want to see what it looks like first, thinking 60mm but might be a bit too low for my liking.. pics please
Threads: 448
51
About 65 on the front 90 rear ![Smile Smile](https://www.306oc.co.uk/forum/images/smilies/smile.png)
On 15" steels 195/50/15 tyres
Threads: 22
Car Model/Spec: 306 1.4
About 80mm front 40mm back.
Threads: 82
27
Hmm.. 60mm might be enough then, i thought it'd be alot lower than that tbh, cheers guys
Threads: 22
Ye im dropping the back of mine another 30mm!
Threads: 6
![[Image: LOW.jpg]](http://i230.photobucket.com/albums/ee213/reed666/LOW.jpg)
65ish mm at the front and around 90mm at the rear.
Threads: 59
Car Model/Spec: 306 D-turbo
This is mine lowered about 80mm on the front and 50mm on the back
Threads: 23
havent got any pics at the moment but ive got mine 30mm front and rear to match and to be honest it doesnt look alot different. having stripped the interior might have something to do with that though maybe
TEAM TRACK CAR + An E60 530d M-Sport for the daily
Threads: 87
31
Jtrigga and Jim are doing it right! 8-) 80mm front and between 40-60mm rear, little bit of front rake is ftw, rear rake looks so poop, imo. Mr Aireys is also a good example!
Threads: 22
Cheers dan! When my new wheels are on the back will be dropping a bit more!
Threads: 53
6
Car Model/Spec: XRdt.
Jtrigga Wrote:This is mine lowered about 80mm on the front and 50mm on the back
![[Image: entrance.jpg]](http://i751.photobucket.com/albums/xx160/jtrigga90/entrance.jpg)
Number plate friend!
How comes you get a ph2 though =/
Surely 184 comes after 173 ^.^
Threads: 22
I think if you spaced the back wheels out it would look awesome! How did you do the fogs?
Threads: 9
19
Given 3 thank(s) in 1 post(s)
60mm ish rear and 90ish on front
Threads: 87
31
<3 Mark :romance-inlove: just needs a bit more stancing at the rear
Toby, jtrigga's is an N reg, so 1995 phase 1, which he converted to phase 3.
Threads: 53
6
Dan! Wrote:<3 Mark :romance-inlove: just needs a bit more stancing at the rear ![Wink Wink](https://www.306oc.co.uk/forum/images/smilies/wink.png)
Toby, jtrigga's is an N reg, so 1995 phase 1, which he converted to phase 3. ![Smile Smile](https://www.306oc.co.uk/forum/images/smilies/smile.png)
Makes sense :oops:
My 1.4 was 40mm and always wanted it another 20mm down! Go with 60 all round imo.
Threads: 9
19
Threads: 48
Threads: 170
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Threads: 177
~90ish, rear to match so the sill was level, its been raised to 60mm as the roads hear are far to bad to be any lower and still have a sub frame
Threads: 22
Threads: 22
Threads: 252
7
Dan thats exactly how i want my front end. Still got the springs?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 252
7
I THINK its down about 80mm but unsure but the front tyre sits just under the arch, Not sure why it is higher on pic above.
Blaze 1.6 Dead
Threads: 171
46
Aparently 45mm on the rear VVV
Threads: 33
Threads: 82
27
I think I'm going to be needing coilovers... 60mm doesnt seem enough now lol
Threads: 22
Threads: 86
60mm front around 75mm rear.
21
55 on the front and back to match. going to get a bit more at the back shortly, just need to get my new wheels on.
