Threads: 33
7
Car Model/Spec: Diablo PH3 2.0HDI
So today I braved the harsh elements and go on with removing the engine a few photos
So now the engines out I can take a look at it all tomorrow there is alot of oil around the turbo pipes at the back and the sump is leaking so far my list consists of the following
Antifreeze
Gearbox oil
Gearbox fork bushes
Radiator plug
Lower ball joint pinch bolts
Wishbone bushes (powerflex)
Engine bay wiring loom
Gaskets - sump inlet rocker
Possibly head gasket and head bolts dependant on how much I get paid from work.
Upper engine mount and gearbox mount
Anti roll bar bushes
That's as far as I've got tonight but will be cleaning the engine up before it goes back in and then ill be seeing what else is needed and update the list.
Will be blocking up the EGR while its out the misses dad will be making some plates for me so that will be done
Clutch and timing belt were both done within the last 10k so just going to double check everything and see if
I can see any signs as to why the engine was being tempremental.
James
Threads: 22
6
Car Model/Spec: 306 HDi Stage 1
26-03-2013, 04:27 AM
(This post was last modified: 26-03-2013, 05:32 AM by gareth7.)
Nice one James, are you removing the whole EGR unit (might as well now mate) or just blanking it?
Thought of loosing the air con too while you've got easy access to everything?
Threads: 33
7
Yes I will be just need two plates making up will be taking it off today and taking a closer look at the engine
Will update as I go along
Threads: 11
Car Model/Spec: xsara Hdi coupe
26-03-2013, 01:02 PM
(This post was last modified: 26-03-2013, 01:03 PM by DaveW.)
Ah turbo swap? its how i would do it...
Threads: 162
21
Given 23 thank(s) in 23 post(s)
Good effort mate. How long did it take to get your engine out?
Threads: 33
7
26-03-2013, 08:23 PM
(This post was last modified: 26-03-2013, 08:29 PM by JamesG.)
Threads: 117
119
Only known of two headgaskets to go on these engines in the three years i've been on the forums, probably not worth it tbh.
That's a normal turbo fitting, got two the same here. No idea what that plastic ring does though, was broken on my old one, took it out and didn't have an issue. That said, i only ran the car for about 1000 miles after taking it out before writing the bugger off, so maybe not a very good example.
Threads: 33
7
(26-03-2013, 09:06 PM)Poodle Wrote: Only known of two headgaskets to go on these engines in the three years i've been on the forums, probably not worth it tbh.
thanks for your reply and i will try and find a replacement but not sure where i can go to get one only other thing is to see what the condition is of the one on the other engine i have at home
not worth it but the discount i can get at work means i should do it i just think id have to skim the head and thats a cost i really cant afford this month and if i was going to do that id overhaul the complete engine!
Threads: 162
21
Did you do any work on it today mate?
Threads: 56
19
Car Model/Spec: Moonstone HDi
Cant wait to get stuck into mine!
Threads: 33
7
28-03-2013, 10:25 PM
(This post was last modified: 28-03-2013, 10:26 PM by JamesG.)
Threads: 33
7
Threads: 162
21
How much did you put in? It should be fine but the car might smoke a bit when you start it up.
Threads: 117
119
It'll just burn off, shouldn't worry about it.
Threads: 386
87
Yeah as said it'll burn off, my rebuilt turbo had some sort of oil inside it from the rebuild and smoked/stank the first drive but was fine after.
Threads: 33
7
29-03-2013, 06:40 PM
(This post was last modified: 29-03-2013, 06:41 PM by JamesG.)
Was 80ml which is nothing really! Cheers guys I kind of knew in the back of my head was just looking for some reassurance ![ThumbsUp ThumbsUp](https://www.306oc.co.uk/forum/images/smilies/legacy/Skype/yes.gif) will be doing the engine bay Sunday so will update the thread when I get some time
Threads: 33
7
Threads: 591
54
have to say the alloy intake pipe for the turbo looks awesome all clean and shiney!...shame it be hidden!
Threads: 33
7
(09-04-2013, 07:57 AM)Piggy Wrote: have to say the alloy intake pipe for the turbo looks awesome all clean and shiney!...shame it be hidden!
It does look lovely and clean behind, shame you can't see it but o well
Threads: 33
7
So the car runs and is fine still have the same problem as before with the error of cylinder reference sensor turns out if you wiggle it the car will start fine in the plus side its boosting better than before and less smoke and no signs of
Leaks from anywhere well worth the time spent on it!!
