Radiator
Radiator
Hi all, I need a new rad for my '6 as mine won't last much longer... There are two on ECP and the only difference I can see is one is 10mm thinner than the other but the price difference is huge!
Is there any difference in these rads performance wise? - does a '6 need the thicker rad?
Any advice would be appreciated, thanks Smile
There are also 2 different fittings from the bottom pipe mate so be sure you get the right fitting. I expect one of those rads is a nissens rad and the other just a standard one
(21-03-2013, 12:23 PM)rocker8742 Wrote: There are also 2 different fittings from the bottom pipe mate so be sure you get the right fitting. I expect one of those rads is a nissens rad and the other just a standard one
ahh thanks, yeah the two im looking at are nissens, just one is £30 and the other is £100 Confused they both look identical, suppose its best to just get the bigger one. I'll measure the pipe as you said to confirm, thanks Smile
Not sure if the size of the pipe is any different but its the fitting that differs
Ok, thanks for your help.
