Radiator - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: Radiator (/showthread.php?tid=12104) |
Radiator - Maxx - 21-03-2013 Hi all, I need a new rad for my '6 as mine won't last much longer... There are two on ECP and the only difference I can see is one is 10mm thinner than the other but the price difference is huge! Is there any difference in these rads performance wise? - does a '6 need the thicker rad? Any advice would be appreciated, thanks
RE: Radiator - rocker8742 - 21-03-2013 There are also 2 different fittings from the bottom pipe mate so be sure you get the right fitting. I expect one of those rads is a nissens rad and the other just a standard one RE: Radiator - Maxx - 21-03-2013 (21-03-2013, 12:23 PM)rocker8742 Wrote: There are also 2 different fittings from the bottom pipe mate so be sure you get the right fitting. I expect one of those rads is a nissens rad and the other just a standard one ahh thanks, yeah the two im looking at are nissens, just one is £30 and the other is £100 they both look identical, suppose its best to just get the bigger one. I'll measure the pipe as you said to confirm, thanks
RE: Radiator - rocker8742 - 21-03-2013 Not sure if the size of the pipe is any different but its the fitting that differs RE: Radiator - Maxx - 22-03-2013 Ok, thanks for your help. |
