no brakes
no brakes
#61
so, dont know what we have done, but the 1st press of the brakes and there awesome, 2nd push still good, then 3rd it gets worse, but if you press them once, then drive for a few seconds then press them again, there good again, its as if you have to wait for the vac to build up so each press is good.
sounds infuriating
have you changed out the vac line from pump to servo, poss a hairline crack or small leak on the line?
havent changed that, but tried it underwater and theres no bubbles.
