Stage 2 Clutch Kit
Stage 2 Clutch Kit
Which gti6 clutch kit are you using?
(12-02-2013, 01:37 PM)Poodle Wrote: Which gti6 clutch kit are you using?
not sure, my mechanic just told me its a clutch from a gti6, took a 70 mile drive today and held the torque very well
The gti6 kit is the same as the XUD clutch kit, good for around 270lb/ft i'd imagine, would've thought the box would've been converted to pull type to use it though?
Was going to say the above, did he do the full conversion then? FYI a standard Gti6/dt clutch will only take fractionally more than the equivalent HDi item, any difference is purely down to the type of mechanism.
(12-02-2013, 06:41 PM)Poodle Wrote: Was going to say the above, did he do the full conversion then? FYI a standard Gti6/dt clutch will only take fractionally more than the equivalent HDi item, any difference is purely down to the type of mechanism.
Couldnt honestly say tbh mate, but i know he had a gti6 in now, not sure if he done full conversion but i will ask Smile
Ah so is this stage 2 mapped? Did LK performance give you a refund on the clutch
S2 HDi >click<
154bhp
280lbs/ft
I am now running a full stage 2 remap I ended up buying a cg 5 paddle Motorsport clutch for 275 pound + postage and I got to says its awesome its really light holds the full power and I was quite worred because people was telling me that paddle clutch are on\off but it's really not that bad I can pull away fine there is a little bit of a snatch but I've only noticed it on a very steep hill but still can pull away fine I really recommend it!!
No refund from LK so far, will be very annoyed if i dont get the refund tbh, so fingers crossed
I've taken a shit in Buckingham palace, does that make me royalty?
Lolol poodle I nearly chocked on my morning porridge...
Seriously tho who's ordered an exedy pro kit... thought they were jdm manufacturers
S2 HDi >click<
154bhp
280lbs/ft
  Best clutch for stage 2 L16rye 4 4,352 15-11-2016, 06:36 PM
Last Post: Poodle
  Clutch kit Stage 2 ? MrBigMac 54 27,582 28-08-2015, 06:30 PM
Last Post: ct-hdi
  Stage 2 Clutch Chris HDI 15 9,001 23-08-2015, 08:28 PM
Last Post: ct-hdi
