06-02-2013, 08:33 PM
Just need some advice, know nothing about beams. But how do i check if the bearings etc are good in a rear beam when its not on a car?
beam condition off car
06-02-2013, 08:36 PM
It's a bit harder to see really, as without the weight of the car there won't be any camber.
06-02-2013, 08:39 PM
Pull the trailing arms of is pretty much the only,
unless its uber f*cked then the trailing arm will have loads of play that you'll be able to feel
See that's what I thought :/ don't want to buy another beam with dead bearings
07-02-2013, 04:42 PM
I've attached a pic of the axle. If anyone has any time to point out on the pic what parts I check would be great
07-02-2013, 10:29 PM
Make sure where the trailing arm goes into the beam with the seal, It's the same gap all the way around, at least this generally gives a good idea that's it is OK or at least rebuild-able
07-02-2013, 11:50 PM
cheers mate i think i know what you mean. so there should be no movement in the trailing arms at all?
08-02-2013, 10:05 AM
You'll be lucky to find any off the car as it all moves around too much
08-02-2013, 12:36 PM
Jump up and down on it, its its f*cked, you'll see stuff moving that shouldnt. Thats not a sure fire way though, if you need to know for sure take the trailing arms off.
