Car Model/Spec: 1.9 Non turbo estate
What cable do I need to sort my door looms out I know I need insulated single core copper cable but what width by this I mean
0.5mm
1.0mm
Etc etc
1.0 Mm multi strand cable. Single strand will snap
The stuff I've found is single core multi strand cable is that what I need ?? Sounds right don't it
(01-02-2013, 01:14 PM)Willo Wrote: The stuff I've found is single core multi strand cable is that what I need ?? Sounds right don't it
Correct
Thank you for the quick answer and advice
Threads: 141
35
what niall said, multicore is also easier to solder
on that note, when your soldering, before you insulate the wire up again, be sure to clean the flux residue from your solder joint as flux will corrode solder weakening the joint, eventually it will break again if you don't.
nailvarnish remover and a cotton bud is ideal way to remove flux
'09 Mercedes E320cdi wagonÂ
Thanks for the tip mate ill do that
Is it just on the bit I solder or the surrounding area ?
