Grafting Gloves
Grafting Gloves
Anyone know of any decent gloves that are waterproof/thermal for general labour around a farm?
For duties like lifting stuff, mucking out stables, and so on.
Also wouldn't mind a pair for specifically doing mechanics as I got girly hands and have more scars then I care to have on my hands. Danny will vouch for this lol!
I've had a little look on the web, nearest thing I can find suitable is motorbike gloves.
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
Gloves, f*cking Gloves! There's only 1 thing gloves should be worn for and that's by the bitch washing the pots!
We have Grips gloves at work which are rubber with fabric backs. I don't use them so can't comment but they look ok quite thick but I would guess if you are using them around water they will get wet. Maybe put some rubber gloves underneath. I find a coating of paint, oil or render keeps them warm Smile
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Tyre fitting gloves are decent
we use these gloves at work
http://www.ebay.co.uk/itm/WATERPROOF-PVC...4d08ef5d54
http://www.ebay.co.uk/itm/12-PAIRS-OF-PO...2ec16c6aff
the top ones will keep your hands dry but are cold,you could wear these inside of them
http://www.ebay.co.uk/itm/12-PAIRS-OF-PO...27caa72e25
http://www.ebay.co.uk/itm/Unisex-Winter-...53f072678f
I use the second ones down on that list, I dont find them cold tbh, the only problem is if you have to put your whole hand in something wet as the back isnt waterproof. However the problem with completely waterproof gloves is that your hands will sweat anyway.....bit of a compromise really. I use them for all sorts of things though, and as they're so cheap just get a new pair when they wear through.
(25-01-2013, 04:29 PM)Toms306 Wrote: I use the second ones down on that list, I dont find them cold tbh, the only problem is if you have to put your whole hand in something wet as the back isnt waterproof. However the problem with completely waterproof gloves is that your hands will sweat anyway.....bit of a compromise really. I use them for all sorts of things though, and as they're so cheap just get a new pair when they wear through.
well i did say the top ones will be cold not the secound ones from the topTongue
(25-01-2013, 03:09 PM)HDIkyle Wrote: Gloves, f*cking Gloves! There's only 1 thing gloves should be worn for and that's by the bitch washing the pots!
we have same gloves with the material backs and there crap soon as they get wet they are crap. have to put them on the heaters in van to dry them out
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
When I'm out on the farm I wear my snap on gloves with extra large disposable gloves on top!
I use the same style of gloves as have already been suggested by most other people in here. However, if you reckon motorbike gloves are the closest thing to what you're looking for, try some winter mountain biking gloves - they're built on the same principles, but designed for much more mobility.
Eg: http://www.chainreactioncycles.com/Model...elID=92509 or http://www.chainreactioncycles.com/Model...delID=9367
At my work we have pairs of "Dirty Rigger" gloves - awesome for the work we do, probably wouldn't be much good for anywhere where there's water... But they're tough and you can feel what's going on at least...
I use a pair of these at work with the weather been cold at the moment 100% waterproof and they're warm too.
SealSkinz Gloves
Some decent suggestions, thanks.
He wants a reusable pair which makes me lean toward pair of snap on gloves (retail £50) but there probably not that suitable for mucking out stables and moving hay.
Hate shopping for birthday presents! :/
S14 Zenki Build
  Fooby and Ruan Grafting down on the farm darrenjlobb 6 4,399 02-06-2013, 09:17 AM
Last Post: Grant
  for those of us that dont use gloves when working... RePT 22 11,928 01-01-2013, 06:07 PM
Last Post: Toms306
