22-01-2013, 02:45 PM
		'Well my sigma is currently on a kkk and OE tune and its a shite turbo IMO takes foreve to boost .'
With an mbc?
With an mbc?
					help with tuning.
With an mbc?
		22-01-2013, 03:45 PM
		summit wrong with it then puglove.....i've had both in tuned state and they're real similar, tune it up and make sure u have no boost leaks and go again
		23-01-2013, 10:01 AM
		Fook that pull the engine out and put my 80k engine in with T2 happy days.
And the kkk is boosting 13psi when ot finaly gets there
		23-01-2013, 10:05 AM
		13 psi? Well why not tune it up then......lot of bother swapping lumps for no reason imo
		23-01-2013, 11:00 AM
	(20-01-2013, 07:56 PM)vlj Wrote:(20-01-2013, 07:54 PM)ginge191 Wrote: Kingy in all fairness mate; you're best off reading around the forum(s). That's one reason, aswell as ease of tuning, better flow with the injectors and generally a much easier pump to use
		23-01-2013, 01:08 PM
		One thing about tuning these, its addictive. Stage one won't be enough, you will always want more, no matter what you tell yourself.
		23-01-2013, 01:56 PM
	(23-01-2013, 10:05 AM)Mattcheese31 Wrote: 13 psi? Well why not tune it up then......lot of bother swapping lumps for no reason imo Meh the other lump is mega low miles and would be a shame to scrap it. Plus its de EGR already tuned and a known goodun. VS a high mileage unknow engine with a shat turbo. So is no question IMO
		23-01-2013, 04:51 PM
	(23-01-2013, 01:56 PM)puglove Wrote:(23-01-2013, 10:05 AM)Mattcheese31 Wrote: 13 psi? Well why not tune it up then......lot of bother swapping lumps for no reason imo i'm not having this talk about it being a shit turbo, it just isn't mate, you need to realise there's summit wrong with your engine or turbo if you think a T2 is that much better . .
		23-01-2013, 05:34 PM
		which clutch would any of you recommend for 150hp+
		23-01-2013, 05:37 PM
		If the pump is standard of course it's going to take ages to kick in, my ph1 with Bosch + k14 took ages to fully kick in when it was standard, it finally got going around 3k rpm. With more fuel it pulls well from 1.5k rpm.
My ph2 came with the Lucas and gt15, turned fuel upto max on the pump and went pretty well, smoke wasn't too bad and was nice to drive. Don't know how a Lucas and a k14 would feel like but it will pick up a lot quicker if you turn up the fuel
		23-01-2013, 05:41 PM
	(23-01-2013, 05:34 PM)craig-dodd Wrote: which clutch would any of you recommend for 150hp+ standard will be fine mate . .
		sound, that will save me some money
