LP pump feed
I've got a battery with a jump pack on it but only getting 9v to my LP pump!
I thoug,ht it was the pump knackerwd so bought a new pump £81 later still didn't work, so ran a live feed from the battery to the pump and hey presto it ran!
What is causing me to only get 9v at the pump? Is it the big brown double relay?
Could be, or could be down to wiring. Probably best to check the feed for consistency before shelling out for a new relay.
Check out the thread by ben hdi306, a few answers and possible causes in there.
Have you tried the red square button behind the ECU? That's what it once was on my car.
remove the brown double relay and check for burned pins in the plug and the relay
Plug and relay don't look burnt anyone local got one I could try?
Where are you?
I'm in Clevedon mate
Oh ok, i can't really pop up the road to stick the car on pp2k then lol.
  No High pressure feed from the Pump miles 16 9,012 14-04-2013, 01:50 PM
Last Post: miles
