19-01-2013, 04:46 PM
Yeah, straight swap.
Another XUD
19-01-2013, 04:59 PM
But only the pump and the injectors,right?
19-01-2013, 05:06 PM
What do you mean? The older full manual pump will go straight on, along with the injectors. Although you can use your current injectors.
19-01-2013, 05:10 PM
And what about the smart injector?
19-01-2013, 05:41 PM
you mean the one with the wire? If so that will be fine just cut the wire off, its not needed. I have a 406 XUD in my 306 and I'm running a manual pump with the original injectors.
19-01-2013, 06:27 PM
leave the injector etc in and get ppo then you really play with the advance springs/ip.
19-01-2013, 09:30 PM
what is ppo?
20-01-2013, 10:27 AM
Peugeot planet, its a diagnostic interface that will let read live data from the engine ecu like rpm/advance/tps, most go by ear with advance/dynamic advance.
20-01-2013, 11:25 AM
Thanks ;]
05-02-2013, 11:03 PM
Another question:
Whant nozzles I must use?...from 2.1 maybe? ![]() |
