Dash lights being random
File Line Function
/global.php 961 eval
File Line Function
File Line Function
File Line Function
File Line Function
/showthread.php 1651 eval
Over the past month, occasionally I would go to my car and the oil, handbrake, stop and the other light have been on, intermittantly though (with no key in ignition)
Also my stereo doesnt work at all.
The dash lights are either dim or shining on full brightness and occasionally changing brightness (like a dimmer switch).
Today I went to my car, and all the said lights were on again, and my glow plug light wouldn't come on and couldnt start the car, unless i turned the key in the barrel a few times, the glow plug light would come on.
I think it might be my igntion switch or an earth problem. What do you think?
Sorry for the long winded story Smile
Check and clean up the dash earth and clean up the battery terminals. My friend had an issue like this turned out to be his battery was dead, could be similar thing?
sounds like a massive ground problem!
  Dash lights Dreijers 5 4,616 01-12-2016, 07:57 AM
Last Post: Dreijers
  Dash lights not on?!help!! Matt_adams 1 2,117 18-05-2016, 07:41 AM
Last Post: aggyj17
  Instrument lights, dash lights not working boggs 3 4,633 26-01-2016, 09:34 PM
Last Post: DeeTurbo
