Threads: 1
13-01-2013, 04:00 PM
(This post was last modified: 13-01-2013, 04:01 PM by jbppug2.)
Hi guys my 306 has been sat still for the last 4 months and i recently changed the front discs and pads as they knacked, and then as i went to use them the brake pedal goes to the floor slowly, so i changed the master cylinder and have bled the system several times, and still the pedal does the same. When the engine is off if i pump the pedal, after a few pushes it goes solid and stays up but when i turn the engine on it goes to the floor and keeps going to the floor very slowly though, does anyone know what could be going on here??
Many thanks in advance
Threads: 206
3
Car Model/Spec: 3dr dt-s
was it a new master cyl or a 2nd hand one ??
sounds like the seals in it have failed either way
Threads: 591
54
with a servo, the brake pedal will eventually go down, very slowly...but very very slowly. Is the pedal a soft or hard initially?
Threads: 28
2
Car Model/Spec: Phase 4 Silver HDi Estate
Given 1 thank(s) in 1 post(s)
Master cylinder seal popped internally. happened on my old one when got over vigorous when bleeding brakes lol
Threads: 136
2
Car Model/Spec: Phase 2 Dturbo
15-01-2013, 07:10 PM
(This post was last modified: 15-01-2013, 07:11 PM by Ben.)
Could it be a leaking vacuum system? Not sure what the vacuum systems for but I think its to do with the brakes!?
Threads: 28
2
new one is like £70 from euros or gsf......
