pug's life D turbo
were do i start ? right so far ive had in the past 3 years 1st (volkswangen polo mk3 6n) that i modified to my liking
and my 2nd car (ford focus zetec ) something to play with
but due to fuel prices i had to find a diesel so i found this blue 306 dt for sale in redruth for 850ono it didnt look to bad for 17300miles but i got it down to 650 as it had no tax
[achment=4216]
it was going well till the radator blown so i had to go out and buy a new one for £110
and at the same time i got a new Thermostat (as ive seen that peugeot have problem's with over heating due to it jamed?)
okay i thuogh it would be easy till i got to the worst pipe fitting at bottom of the rad ( it had taken about 1 hour to take off) but to the point i think it have gone past it Sad
after i fitted the rad. it started to over heat again after 3 days, i did a head gasket test but had failed so i had to get new HG,head kit,cambelt,(water pump just on the safe side) oil filter,fuel filter,and new head bolt's at the same time £200 Sad
okay i will let the pictures do the talking
You've moved onto the right car anyway!
You need to lose the wheels, stickers & lexus rear lights ASAP, but you've got an epic engine to play with and one of the best colours... good luck!
agreed and looks like youll be needing a new beam soon to looks likes its cambered Sad whats the plan dude?
ok got the photo order wrong Sad
i had a few days off because i had to wait for some more parts to come so i got some new egde 6.5 componts . got them fitted nicely
lost the other pic Sad and started to tint my rear windows and changed the side repeaters
well after 2 weeks of finishing the car it still want running right thought it was a fuel problem, so to the garage it wait. after 7hours being down there i got told it was the timing out by one nouch so the car is running like a new car Smile next on my list
ph 2 front lights ?
de badge front grill
smooth bumpers (spliter)
sideskirts ?
change back box
lower 40mm
new disc's
carbon fibre warp bits
(08-01-2013, 09:17 PM)sam Wrote: agreed and looks like youll be needing a new beam soon to looks likes its cambered Sad whats the plan dude?
my plan is
ph 2 front lights ?
sideskirts ?
change back box
lower 40mm (rear beam is new ish )
new disc's
