Threads: 30
Given 1 thank(s) in 1 post(s)
cant see any reason why it wouldnt work as far as im a wear thats where the std counter picks up from!
Threads: 541
124
wont work mate. needs an electronic wire to connect to such as a coil trigger wire. the XUD has nothing similar.
You need to get the sensor off a 306 and bolt it in to the 205 then nick the gubbins out a 306 rev gauge and wire it up.
Threads: 541
124
back of the block on the webbing that faces the fly wheel
Threads: 266
18
Car Model/Spec: 205 DTurbo
Given 7 thank(s) in 7 post(s)
I've seen a 106 1.9 XUD on YT with an after market rev counter. There must be a way surely? Even if it involves using the 306 tacho sensor thingy?
Threads: 55
3
(31-12-2012, 02:44 PM)Dum-Dum Wrote: back of the block on the webbing that faces the fly wheel
This, make sure you give it a good clean before you put it back on
Fabia vRS PD130 - New daily
Astra H VXR - new toy!
Threads: 91
83
I can't remember exactly if after market rev counters can read the standard VR sensor on the back of the block...
However, if you know the ratio, you can use the W terminal on the alternator...
(16-05-2016, 10:45 AM)Toms306 Wrote: Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in.
Threads: 90
54
W terminal on alternator is easiest way, the stock sensor is a farce to get working with anything other than the stock dashs'
Threads: 119
5
Car Model/Spec: MG ZS180
How would you set it up on the alternator though?
Threads: 266
18
Darren & Ruan my alternator looks different to my 306's I'm guessing its the 205 one, the belts all look a lot thinner too.
Would the gauge I originally linked on eBay connect up to this W terminal?
Threads: 119
5
so if you knew the size of the crank pulley and the size of the alternator pulley, you could work out the ratio, then work a rev counter from that?
