Threads: 226
24
Car Model/Spec: A3 TDi
The title is there to grab your attention hope it worked! Basically i need some help with the interior fan in my car im hoping someone can get me a circuit diagram so i can figure out how the system works(the resistor the fan speed selector etcetc). We had autodata at college but i cant use the login unless im on one of there computers!
Threads: 206
3
Car Model/Spec: 3dr dt-s
can you access your college account from home ? most colleges allow a student portal so they can happily work from home and do hours of self-study ??
Threads: 226
24
I think its expired now i left in june haha
Threads: 465
114
Car Model/Spec: Vauxhall
tom give me the model of car engine aicon? and build number code and i try to get it off service box for you
Threads: 226
24
1996 D Turbo non aircon.. Where would i find the build number code?
Threads: 465
114
try this see if this looks right
xuddt.pdf (Size: 385.18 KB / Downloads: 153)
Threads: 226
24
29-12-2012, 05:13 PM
(This post was last modified: 29-12-2012, 05:39 PM by Tom.)
Cheers for that, think i misjudged my ability to read an electrical diagram though lol
If anyone wants to look at that electrical diagram and tell me what you think it would be nice. Basically the black plug isnt grounded atall, and the red plug is constantly 12v regardless of switch position. So im thinking i have 2 separate issues.
Threads: 226
24
Right i need some help. Anyone?
Threads: 465
114
Threads: 226
24
With this shit problem i have. Basically the black plug isnt grounded atall, and the red plug is constantly 12v regardless of switch position. So im thinking i have 2 separate issues.
If i use the ground for the motor with my multi meter it says its 2v.. if i ground the meter somewhere else it tells me that the red wire to the motor is constantly 12v...
Threads: 465
114
you need to help me out here tom
where is the black plug ?
is it
1.on the fan
2.on the heater control knob
where is the red plug?
what colour is the plug in the resistor pack
brown?
Threads: 226
24
The black and red plugs in question are the ones that go to the fan. I think the plug on the resistor is brown yes, Is the resistor in the air intake behind the top glove box?
Threads: 465
114
when you say red and black plug on the fan i think you are saying the wire colours not the plug colour
if that is correct
yes one wire to the fan will be live 12v all the time with the ign on
the speed is controlled by switching more resistors in the 0v side of the fan 0v wire
Threads: 226
24
So do i need to measure the resistance from the 0v wire on the fan to a ground and that will tell me if its the resistor thats broked? But then if the speed selection switch isnt working i wont get correct resistance readings anyway?
I was saying wire colours yes, the Red wire has a green plug i believe thats the constant 12v one.
And the Black wire i honestly cant remember what colour plug was on it, tempted to say black, but its late.
Thanks for your help so far mate, my electrical knowledge only goes so far lol.
Threads: 465
114
01-01-2013, 11:47 AM
(This post was last modified: 01-01-2013, 11:50 AM by cully.)
first i would test the fan!
how
find the 12v wire on the Fan plug make sure it is at 12v
then take a spare piece of cable put it to the chasis earth and dab the other end of it on the black 0v wire at the fan
the fan should run at full speed
this will prove the fan is ok
Threads: 226
24
Already done this fan works perfectly. and i have the full 12v on the red wire
Threads: 465
114
cool
now your going to test the resistor
turn the ignition off
unplug the resistor
set your meter to ohms
touch both ends of the probs together meter should read 0/zero ohms or very close
on the resistor you should be able to see pin numbers if you have good eyesight
measure the resistance from pin4 on the resistor to pin 6 you should get a reading
them measure between
4-5
4-1
4-2
each reading should get less than the first reading you took at 4-6
Threads: 226
24
Can i get to the resistor by removing the top glove box?
Threads: 465
114
to be honest i dont know where it is im just working from the drawing i posted
is it not near the air intake under the wiper arms?
Threads: 226
24
There is a funny looking thing with like coils sat in there with a brown plug. But i cant remember if it was accessible via the top glove box... Im all the way up bude for lunch today anyway so wont have time to look until i get home later anyways! I will report back with readings etc when its done
Threads: 465
114
funny thing with coils with a brown plug sounds about right
Threads: 386
87
Its under the scuttle on ph1s afaik.
Threads: 226
24
Right i found it, i get no readings anywhere. Regardless of meter settings, i get no readings on any pins. What the actual shit f*ck does that mean. It physically looks fine, no coils f*cked and hanging off :/
Threads: 465
114
02-01-2013, 05:47 PM
(This post was last modified: 02-01-2013, 05:53 PM by cully.)
no reading across any pin at all? you are measuring the resistor coil thing with the brown plug not the wires?
if you have your meter on ohms and you test the meter by touching the prob's the reading should be low ie:0-1-2
if that right
id say that the resistor was pritty fecked thats why you have no earth path from the motor
to prove wiring and the switch works and the fan in the car
link pins at the resistor end plug (wire side) with a piece of wire
link
pins 4-2 (fan should work at full speed setting)
pins 4-1(fan should work at third speed setting)
pins 4-5(fan should work at second speed setting)
pins 4-6(fan should work at first speed setting)
Threads: 226
24
Yeah the resistor pack very strange how theres nothing at all. Will link the pins tomorrow when i have some light, hate working in the rain.
Threads: 226
24
Replaced with one from scrappy works again, switch doesnt work on 3 or 4. The one from the scrappy looks shit and works and my original looks newish and is broke... wtf
Threads: 226
24
Just to bump up an old thread just had exactly the same problem again. Another resistor f*cked :/
