Hub nut size
Hub nut size
Anyone know what size the hub nut is
mines 35mm
(21-12-2012, 05:07 PM)cully Wrote: mines 35mm
same here
snap. mine same
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Sweet just gotta go get one now
Yeah there 35mm haven't come across 1 that isn't yet. I got some spare if your after 1?
I once had a 34 i think it was. But that was becasue the 36mm socket i used to remove it only worked by removing the edges because i wanted to be cheap. However you try removing arounded hubnut!! Get a 35mm to start with Lol
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
I did the near side with a hammer and chisel
35mm front 32mm back . . .Smile
Some front ones are 32mm I bought a wheel bearing kit that came with a 32mm but just used to old one
could only find a 36 due to the festive season so fingers crossed if not hammer time
originally they were 35s but some replacement kits can be any size around that. 36 does fine seeing as halfords dont do a 35.
never been able to find a 35mm when needed n got 36mm lol..not had no bother yet thank god Smile
Yeah a 36mm impact socket from hellfrauds was all I could find and it was fine Big Grin
I got 36mm hub but from my local motor factors
