Hub nut size - Printable Version
+--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19)
+--- Thread: Hub nut size (/showthread.php?tid=9138)
Hub nut size - smokey - 21-12-2012
Anyone know what size the hub nut is
RE: Hub nut size - cully - 21-12-2012
mines 35mm
RE: Hub nut size - samass - 21-12-2012
(21-12-2012, 05:07 PM)cully Wrote: mines 35mm
same here
RE: Hub nut size - karl1989 - 21-12-2012
snap. mine same
RE: Hub nut size - smokey - 21-12-2012
Sweet just gotta go get one now
Hub nut size - Frosty - 21-12-2012
Yeah there 35mm haven't come across 1 that isn't yet. I got some spare if your after 1?
RE: Hub nut size - HDIkyle - 21-12-2012
I once had a 34 i think it was. But that was becasue the 36mm socket i used to remove it only worked by removing the edges because i wanted to be cheap. However you try removing arounded hubnut!! Get a 35mm to start with Lol
I did the near side with a hammer and chisel
RE: Hub nut size - Mattcheese31 - 21-12-2012
35mm front 32mm back . . .Smile
RE: Hub nut size - Connor - 22-12-2012
Some front ones are 32mm I bought a wheel bearing kit that came with a 32mm but just used to old one
RE: Hub nut size - smokey - 24-12-2012
could only find a 36 due to the festive season so fingers crossed if not hammer time
RE: Hub nut size - Niall - 24-12-2012
originally they were 35s but some replacement kits can be any size around that. 36 does fine seeing as halfords dont do a 35.
RE: Hub nut size - Peugeot Enthusiasts Group - 28-12-2012
never been able to find a 35mm when needed n got 36mm lol..not had no bother yet thank god Smile
RE: Hub nut size - Jonny81191 - 28-12-2012
Yeah a 36mm impact socket from hellfrauds was all I could find and it was fine Big Grin
Hub nut size - kentiiboii - 28-12-2012
I got 36mm hub but from my local motor factors
