Threads: 180
21
Car Model/Spec: Broken Phase 2 GTi6
1 know the following things:
-Battery aint great
(gauges flashed all full then back to bottom again), but its always turned over/started.
-Possible key/immobiliser issue.
Sometimes it just turns over and doesn't start. Pull the key out, put it in and start again, fires first time (rare, 1 in 10/15 times)
First time up in Cumbria with this car, left it standing for about 48hours in what has most likely been the coldest its ever been since I've had it.
Car turns over ok, but refuses to fire.
I've locked/unlocked the doors, with the remote fob a few times. Turned over a few times but still never fired.
obviously, battery is a little tired now, so i'm tempted for the sake of it to just replace the battery as first point of call.. but since it turns over I figured it would be alright?
Immobiliser issue has turned into a permanent fault... unknown if that's the case, is there any way i can test? All my spare keys are at home.
I do have RAC and I will phone them if required, just don't want them to rock up and tell me something obvious.
1. Fooby's Car
2. Fooby's Hire Car(s)
3. Fooby's Company Pool Car
Team Self Improvement
1. Learn to Car
Threads: 87
48
my Citroen Dispatch with HDI 90 engine is the same needs jumping all the time when it's quite cold and it's got a 2 year old Bosch battery on as well, turns over but doesn't catch.
Threads: 63
26
Car Model/Spec: GTi6
If its turning over as normal then I can't imagine the battery is at fault.
I had exactly the same problem with my XSi - it was intermittent but I couldn't seem to find a fix, it was ages ago but if your key is in and you press the button on your steering wheel for 5s doesn't it disable the immo?
Threads: 180
21
is that what that does?!?!
I'll give that a press after i've heard other thoughts, since i probably only have about 1 more attempt at starting before i will need a jump, which might not be the easiest given I am no-where to be found
1. Fooby's Car
1. Learn to Car
Threads: 138
72
Car Model/Spec: Mincebus
Should drive the gti6 more
Astor 'X' 4 GTi6- 6 - SOLD!
Threads: 180
21
(11-12-2012, 12:45 PM)Ed Doe Wrote: Should drive the gti6 more
helpful as always
1. Fooby's Car
1. Learn to Car
Threads: 138
72
(11-12-2012, 12:54 PM)Fooby Wrote: (11-12-2012, 12:45 PM)Ed Doe Wrote: Should drive the gti6 more
helpful as always
Did you expect any different?
You tried bumping it?
Did the button you tried a minute ago work in the end or not?
have you double-locked it, then unlocked it?
Have you jiggled the key in the ignition barrel?
Threads: 63
26
Threads: 180
21
I've double locked it every time as part of my lock/unlock method.
I've not tried the button yet as i only have 1 more attempt then the battery will most likely be flat.
I've not jiggled it no, but i can try that
1. Fooby's Car
1. Learn to Car
Threads: 138
72
Well if your battery is nearly dead I'd start by getting it jumped mate. Sounds a lot like it's not even cranking fast enough to start anyway...
Threads: 90
Shitty ecu probs not coming up with starting amps being raped from a naff battery, try bumping it / put set of leads on it and see if it will start...dont you carry a can of ether?
Threads: 180
21
that makes more sense darren!!
I'll buy a new battery me thinks. I'll get a jump. Thanks for your help and fyc ed
1. Fooby's Car
1. Learn to Car
Threads: 202
58
Are you stuck in Cumbria mate?
I'll come and tow it to mine, I'm sure we can get it fixed, if not at least it gives you a secure place to leave it for a week or so if needs must..
Threads: 180
21
Na I'm good. Mate,.Darren you were.right battery voltage. I'm going to halfrauds now.for a battery. What one do I want?
1. Fooby's Car
1. Learn to Car
Threads: 130
82
Car Model/Spec: 106 GO-NAD
couple of D cells.
Threads: 90
Just get most cranking amps u can, making sure battery will fit in the box
Threads: 180
21
610 Bosch cranking amps it is.
/bends over
1. Fooby's Car
1. Learn to Car
Threads: 3
Car Model/Spec: 306 HDi D Turbo
It's a long shot, but maybe it's the Racoon Filter?
Threads: 180
21
127 quid later...
1. Fooby's Car
1. Learn to Car
Threads: 289
92
Car Model/Spec: Phase 17 R26
 can't believe it too that long to be suggested! Well played though the haha
Adam I hope you have a trade card??
Threads: 50
14
Car Model/Spec: Nile Phase 2.5 GTI6
Also, didn't you buy a battery for it the day after the Ace meet, when we all went to Watford?!
11-12-2012, 02:20 PM
(This post was last modified: 11-12-2012, 02:22 PM by Toms306.)
(11-12-2012, 02:01 PM)Fooby Wrote: 127 quid later...
How much!?
I got a Bosch silver 5 year warranty for my HDi for like £50 after a bit of discount. You shoulda gone to ECP lol.
That one - http://www.eurocarparts.com/ecp/c/Peugeo...965&000020
Threads: 180
21
yeah, it was a bosch silver one, no trade car for me. Just bum rapeage.
I knew the battery was cack but i figured as long as i could crank it, it would start.
Think its time to sack of this EUC, piece of. MHDi pwease Darren?
Thanks again for the offer of help Johnny
1. Fooby's Car
1. Learn to Car
Threads: 448
51
Glad it's sorted. I would hve just proceeded to lol at you, because at some point, you would have fallen over
Threads: 180
21
nearly fking did!!
1. Fooby's Car
1. Learn to Car
Threads: 448
51
Haha must be chaos for you this time of year. All this ice and the incabability of actually staying upright
Threads: 138
72
In breaking news..... Fooby fits something to his car. On his own. With no adult to hold his hand.
Threads: 180
21
(11-12-2012, 03:13 PM)Ed Doe Wrote: In breaking news..... Fooby fits something to his car. On his own. With no adult to hold his hand.
wrong,
i had to pay the man, i had no tools to disconnect the battery box!!!
1. Fooby's Car
1. Learn to Car
Threads: 202
58
Why the hell were driving a 306 without tools?
It's like the 11th commandment "if thou owns an automobile of the peugeot 306 variety, thou must carry the equipment required to remove all of it's component parts"
Threads: 90
For the reference, if you had mtdi'ed it and put the shitty ecu in the bin, it would have started easily  as long as the cuss will motor, it will fire
