Threads: 591
54
Done some searching and a lot of reading but nothing quite hit the spot...
is there a LSD for the xud/hdi box...? obviously aftermarket.
Also, what is the best boost controller out there...dont fancy buying a cheap one on fleebay...but there dont seem any good quality ones out there.
Also, which type is better??...
http://www.ebay.co.uk/itm/TURBO-MANUAL-B...33590834bd
or
http://www.ebay.co.uk/itm/BLACK-UNIVERSA...5d3704bc69
thanks in advance
Threads: 198
135
First one for the MBC mate, its a ball and spring type that doesn't vent to atmosphere. The bleed type valves make the wastegate less efficient and make the turbo work harder to maintain boost pressure with what is effectively a boost leak
Threads: 136
2
Car Model/Spec: Phase 2 Dturbo
Given 1 thank(s) in 1 post(s)
Pretty sure you can get LSD's for our boxes. Look at JP's project thread because I think he fitted the one to his gti that he origionally bought for his dt
Threads: 127
33
Car Model/Spec: ZX Volcane TD
I had two of those ball bearing type, and im almost certain either they're broke or they vent to atmosphere as standard - i can hear them pssssshing out that little pin hole they have.
Threads: 198
135
The pin hole's supposed to be a pressure relief valve to allow the ball to reseat again when boost drops.
In light of having no working wastegate i'm using mine as a 45psi block to stop the wastegate opening for now
Threads: 100
12
Car Model/Spec: 306 dturbo Ultra Spec
You can use any of the LSD's that work on the 6 boxes with our boxes.
Threads: 591
54
thanks ya'll
for the MBC can I position it a few more inches away from turbo than the actuator, as in to hand when you lift the lid....that wont affect it?
interesting on the '6 lsd...shame they didnt do a LSD in the rallye
Threads: 130
82
Car Model/Spec: 106 GO-NAD
he means that any aftermarket lsd for the GTi 6 will fit in a DT box, not that pug put an LSD in the '6 as standard...
Threads: 591
54
yeah yeah I know...as in good that a LSD for a '6...which one can buy...fits a dtub, which one cannot buy.
I meant the rallye SHOULD have had one...
Threads: 130
82
well, if it fits a '6, it'll fit a rallye obv, just generally the case that stuff gets marketed for the '6 as it's the more common car. but yeah, i get your point, seeing as it's the rallye, and it's meant to the 'sportiest', then an lsd would have been nice
Threads: 91
12
Car Model/Spec: 306 D Turbo
Threads: 28
2
Car Model/Spec: Phase 4 Silver HDi Estate
that's a rip off lol
http://www.rallydesign.co.uk/product_inf...ts_id=7242
still shocking but more reasonable
Threads: 130
82
Yep, complicated bits of kit, don't come cheap lol
Threads: 591
54
rallye so should have had one as standard...all the rallyes actually
yeah they very expensive...have to do more digging...ford ones are dirt cheap now coz so many around
Threads: 28
2
07-12-2012, 10:38 PM
(This post was last modified: 07-12-2012, 10:43 PM by Kwik.)
peugeot sport (ZF) lsd for be type gearbox's but what came with them as standard?lol
edit; did more reading and you need different shafts AND they more expensive then the quaife one lol
On my e30 323i i just got a lsd from the breakers lol. liked it alot lol
Threads: 591
54
07-12-2012, 11:06 PM
(This post was last modified: 07-12-2012, 11:06 PM by Piggy.)
what about the MCB...does it make a difference to run piping away from turbo?
(07-12-2012, 10:38 PM)Kwik Wrote: peugeot sport (ZF) lsd for be type gearbox's but what came with them as standard?lol
yeah annoying
Threads: 130
82
in theory, yes, cuz it'll delay the reaction time of the waste gate or something, but you'd never notice a difference
Threads: 91
83
It'll spike boost more the further you put it away... I.e. say its sat at 24psi, it'll jump to 28psi as soon as you get on the throttle then fall back to 24psi... Not the best for the turbo...
(16-05-2016, 10:45 AM)Toms306 Wrote: Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in. Nanstone GTD5 GT17S - XUD9TE
Threads: 591
54
so within what limit is best??
Threads: 591
54
these LSDs are mega bucks man...looking 550+....the BE3 box though appears to be used in the 205 rally cars a lot...so doing some digging with old contacts to see if I can bag me one from that way...
Threads: 100
12
If you can get hold of two cheaply would be better. Since I would like one too.
Threads: 28
2
lol mark the 205 rally ones used ZF ones which need different shafts as i said in my earlier post. best thing to do is keep an ear to the ground for a second hand quaife
Threads: 100
12
That's what I meant. Can't be bothered with changing the shafts.
Threads: 28
2
you would have to change shafts if he sourced one from a 205 rally..............
as they are ZF ones. Not a straight swap by a long way........
Threads: 100
12
I know I meant if he could find a few tran x or quaife ones.
Threads: 28
2
if he did they would be from private competitors and not works ones
Threads: 591
54
I only know private comps....duno though...may still strike out
