Threads: 5
Car Model/Spec: 306 D turbo
Morning chaps,
So on my home last night, the my clutch started to stick. So when I go to change gear, I put it in said gear, then lift and the clutch stays down, and doesn't come back up.
Similar with the accelerator cable too.... But this does come back up, but it feels really sticky and extremely.... spongey at times too.
New cables?
Threads: 252
7
Car Model/Spec: Xud sedan/Xud estate
Sounds like cables yes. My HDI clutch cable sticks down sometimes just needs a flick with your foot from behind. Only now and again but getting more frequent causes the clutch to slip which is annoying as sometimes it sticks for abit then pops up causing the car to jerk
TD04 11mm Sedan, now 2.1 vnt
Sedan Project
http://306oc.co.uk/forum/thread-5763.html
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 130
82
Car Model/Spec: 106 GO-NAD
Yep, first port of call is the cables
Threads: 5
Cheers guys, I thought it would be. Still learning the ropes with these cars. Fix one issue, then a million more appear out of no where!
Threads: 5
29-11-2012, 01:07 PM
(This post was last modified: 29-11-2012, 01:35 PM by davalav.)
I wish... I know basics. But I like to post just to see if any one else has had the same or similar issue! I hate being in doubt, leaving it and then it gets worse!
[/quote]atleast you get to fix one first, that happens even before the first one has been fixed usually![/quote]
Hahaha! A few weeks ago I had air in the fuel system, accidentially over tightened and snapped a bolt on top of the fuel filter housing! Got some uprated bolts, fixed that then chronic boost leaks! Turns out it was the D seal. Fixed that now the steering whines and the clutch and accelerator stick!!!
