so what are the stock power and torque for a 2.1?
108hp but what is torque?
2.1TD Swap
24-11-2012, 07:01 PM
110bhp and 185lb/ft mate.
the peak torque is at 2000rpm, thats motorway cruising at 60mph on a HDi box so when tuned it should do some pretty effortless overtakes.
24-11-2012, 07:04 PM
nice can't wait or this now but not doing mine lol
24-11-2012, 07:58 PM
FMIC is bought so i can do this conversion justice. That has hurt alot. £145 posted for a fair sized FMIC kit off ebay and another £50 on silicone bends to make a good fit of it all. Thats a £200 sting I hadn't really budgeted on.
24-11-2012, 09:57 PM
I've got loads of brand new T-bar clamps if you need them, I've got 60-63 and 65-68 or around that.
Stage 2 XUD Sedan
25-11-2012, 05:11 PM
Spent far too much today again, about £200
bosch duraterms 5l oil oil filter fuel filter valeo clutch kit rocker cover gasket gear oil coolant The duraterms were a bargain, less than £25 for 4 on halfords trade. Its all off to Kris's tomorrow for fitting to start.
25-11-2012, 10:59 PM
26-11-2012, 10:18 AM
Dum,
2.1 xud rods are meaty... I was going to put some in mine. Get a cg clutch on it, decent turbo and wind it up!
JP
26-11-2012, 01:13 PM
Does the same rule apply to 2.1 rods that applies to 1.9/2.0hdi rods and that would be that the 2.2 Hdi rods are an upgrade to the 2.1 items or do they not fit - anyone know?
26-11-2012, 02:57 PM
(26-11-2012, 01:13 PM)ash240970 Wrote: Does the same rule apply to 2.1 rods that applies to 1.9/2.0hdi rods and that would be that the 2.2 Hdi rods are an upgrade to the 2.1 items or do they not fit - anyone know? iirc the 2.1 is totally different to all you mentions as the crank has a longer throw so would be a shorter rod, Im trying to find out the dimensions of both because i want to get a custom size rodfor a build ![]() ![]()
26-11-2012, 09:06 PM
26-11-2012, 09:08 PM
You gonna be getting a fmic, or keeping it top mounted for the ultra oem look?
I have just spotted this....very interested...because...
I have a 2.1 arriving on thursday...got it for 180 delivered with box/turbo/all ancillaries...so selling the bits I dont need to pay for the engine! lol! It had only done 90k too. But rebuilding it over the winter, new rings, hone the bores etc, skim head etc etc Also got a HDI box on the way! lol! Already got me a boxer intercooler for a tenner!! lol! Also putting a bosch 11mm hybrid as the one thats coming has got the lucas on it. Theres a guy on 306pug.net who did this...he rerouted the turbo to on top of the gearbox...bigger turbo mind. Have I missed what pump you are using? ![]() Will have to put my project up on this site is this the 2.1 IN? Looks like a XUD turbo intake?! also, lots of talk on the 306pug forum about decent clutches to take the torque... was deemed after a lot of discussion and research and chats with companies that the latest Sachs clutch kit for 2.0hdis, 306/berlingo, has a rated power of 280ftlbs of torque. just a thought ![]() Wishes for more power...
26-11-2012, 09:33 PM
26-11-2012, 09:34 PM
(26-11-2012, 09:17 PM)Piggy1987 Wrote: also, lots of talk on the 306pug forum about decent clutches to take the torque...the stock XUD Dturbo valeo holds that torque as it's a Pull type and not a push type
26-11-2012, 09:37 PM
CG paddle clutch ftw and very reasonably priced too, i was lucky to get new unused on ebay for 70nicker
![]() Worry about whether it can handle to torque when you have actually got near that figuire ![]() ![]()
26-11-2012, 09:39 PM
CJ the stock XUD one is enough up to that figure so no need to spend mega bucks. He just has to change the clutch fork and use his 1.9 flywheel to mount the XUD Pull type clutch
26-11-2012, 09:41 PM
Darrens been using one and if it can survive Darrens contraptions I'm sure it'll be fine.
Stage 2 XUD Sedan
(26-11-2012, 09:08 PM)ozonehostile Wrote: You gonna be getting a fmic, or keeping it top mounted for the ultra oem look?Yeah FMIC is on order, just a little one but itll be big enough and certainly better than the TMIC. Its not possible to fit a TMIC to the 2.1 without custom manifolds. (26-11-2012, 09:17 PM)Piggy1987 Wrote: I have just spotted this....very interested...because...2.1TD bits dont go for much as lots of people buy the engines for conversions (in TATA and Sizuki 4x4s usually) and they sell the ancillarys too. Im not sure Id bother about the rebuild, Ive seen the insides of many 100k engines still have the factory honing marks. Whats the boxxer intercooler like. Ive looked at alot of OEM intercoolers and ATM anything the right size and shape with exits in the right place costs close on what a more efficient universal one costs. Mine is getting a 9mm pump from my 1.9TD for the minute until I can afford a rebuild. Ive seen the thread on .net (youll notice ive posted in it). I want mine to look OEM so the turbo is staying round the back. (26-11-2012, 09:17 PM)Piggy1987 Wrote: also, lots of talk on the 306pug forum about decent clutches to take the torque...A £100 Valeo from ECP will hold 280lb/ft too. I will probably go for a Helix if/when I need one. For now the 280lb/ft limit will probably be good for now especially as a doubt my tyres would cope with 280lb/ft in anything but 4th and 5th even in a straight line. (26-11-2012, 09:41 PM)strictly_derv Wrote: Darrens been using one and if it can survive Darrens contraptions I'm sure it'll be fine. Me and Darren are looking for different things from our cars. Darrens cars are rev monsters that actually dont make huge torque because the boost comes in so high up the rev range. This is looking to be at full boost around 2krpm and that means HUGE torque and thats whatll kill the clutch.
26-11-2012, 09:48 PM
Newbies ehh
26-11-2012, 09:54 PM
They rated mine to 350lb/ft and I never had it slip, even with 320lb/ft, and full throttle 2nd gear launches.
JP
JP
26-11-2012, 10:02 PM
Now thats what i like to hear
26-11-2012, 10:04 PM
I will avoid CG at all costs as theyer a bunch of lady gardens with no aftersales service. They dont care as long as they have got your money and put some shit in a box for you. It working properly or for any length of time seems irrelevant to them.
Interesting...hmmm
So what turbo are you using then?! Yeah im powerlfex bushjng and coilovering to cope with +torque (19-11-2012, 01:03 PM)darrenjlobb Wrote: As people said it would be intresting to see...but the way i see it, is its just everything I dont want... but whats the point in revving a diesel to the red line!?! if you want a revvy car buy a Gti! Wishes for more power...
26-11-2012, 10:20 PM
Im using the turbo that came with the engine as it dosent appear to be a standard one
27-11-2012, 10:42 AM
