Threads: 117
21
Car Model/Spec: needs bwarrrp.
Given 1 thank(s) in 1 post(s)
Right, I've got a horrible noise coming from around pullies or that kind of area.
I've been told it was my water pump so I had that changed along with the cam belt but the noise is still their. Then I was told it was the idler pullie so changed that but the noise is still their so now it only leaves the a/c pump. Now, do I risk getting a new one or is it a case of putting a smaller belt in to by pass the pump.
Threads: 202
58
take the belt off, run the car. it'll at least tell you if it's aux belt or cambelt
Threads: 151
14
Car Model/Spec: 306 D-turbo
I have a working air con pump if you need one.
But the sake of 5 minutes whip the belt off to see if the noise goes
Team Doesn't own a 306
Threads: 117
21
Will crack on with that when I get time. Cheers.
Threads: 117
21
right, im needing a air con pump so anyone got one for me? price posted please and obviously good working condition.
Threads: 0
45
Ask dan if mines still at his, cover postage & you can have it
Threads: 87
31
Roger that, will check tomorrow evening. Pretty sure it's still under the bench :-)
Threads: 117
21
kinda likeing the 55k one. cheers anyway dan/jj006667744. price matey please. need it asap.
