running without a/c - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23) +--- Thread: running without a/c (/showthread.php?tid=7407) |
running without a/c - kingy - 27-10-2012 Right, I've got a horrible noise coming from around pullies or that kind of area. I've been told it was my water pump so I had that changed along with the cam belt but the noise is still their. Then I was told it was the idler pullie so changed that but the noise is still their so now it only leaves the a/c pump. Now, do I risk getting a new one or is it a case of putting a smaller belt in to by pass the pump. RE: running without a/c - Jonny81191 - 27-10-2012 take the belt off, run the car. it'll at least tell you if it's aux belt or cambelt RE: running without a/c - kingy - 27-10-2012 (27-10-2012, 08:47 AM)Jonny81191 Wrote: take the belt off, run the car. it'll at least tell you if it's aux belt or cambelt Had all belts changed RE: running without a/c - Danny2009 - 27-10-2012 I have a working air con pump if you need one. But the sake of 5 minutes whip the belt off to see if the noise goes RE: running without a/c - kingy - 27-10-2012 Will crack on with that when I get time. Cheers. RE: running without a/c - kingy - 25-11-2012 right, im needing a air con pump so anyone got one for me? price posted please and obviously good working condition. RE: running without a/c - 1616six - 25-11-2012 Ask dan if mines still at his, cover postage & you can have it Re: running without a/c - Dan! - 25-11-2012 Roger that, will check tomorrow evening. Pretty sure it's still under the bench :-) RE: running without a/c - spike2002 - 25-11-2012 I still have a 55k one ![]() RE: running without a/c - kingy - 25-11-2012 kinda likeing the 55k one. cheers anyway dan/jj006667744. price matey please. need it asap. RE: running without a/c - spike2002 - 25-11-2012 You have pm ![]() |
