Threads: 170
hi guys im changing my rear axle to a HDI axle and was wondering if there is anymore stuff that i need apart from handbrake cables?. are the brake pipes the same?.
cheers karl
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Threads: 115
26
Car Model/Spec: 306
Threads: 170
ye mate. sorry forgot to mension
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 177
Must be atleast 100 threads asking this question
Threads: 115
26
Car Model/Spec: 306
24-11-2012, 11:18 PM
(This post was last modified: 24-11-2012, 11:21 PM by spike2002.)
The phase3 hdi beam won't have a brake compensator
I went from drums to a hdi beam on my non abs 1.6 and didn't fit a compensator and the rear used to lock up under hard brakeing
Threads: 23
Ph3 cars have a special abs pump so they don't have need for a compensator.
And if your locking your wheels up with no abs, don't brake so hard and get better tyres lol
My Dimma has no abs and I've only ever locked it up twice in 3 years of owning it
Threads: 119
Car Model/Spec: MG ZS180
Could always fit the compensator from your old beam if you don't have ABS.
Threads: 170
i do have ABS
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 115
26
Car Model/Spec: 306
(24-11-2012, 11:40 PM)Birk Wrote: Ph3 cars have a special abs pump so they don't have need for a compensator.
I was telling the op if he doesn't have abs and fits a beam with no compensator there is a good chance the rears will lock up. Under hard breaking eg emergency stops. Not normal driveing. My old car was a phase1 1.6 no abs and I fitted a beam off a hdi and didn't fit a compensator hence the rears locking up.
As you say the phase3 doesn't need a compensator as the abs pump is different but being a phase 2 it will need the abs and a compensator to work as it should. Granted half the time the compensater is seized any way lol
Threads: 170
ah ok. is it easy to fit the compensator if i get a axle without one?
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 115
26
Car Model/Spec: 306
25-11-2012, 01:06 AM
(This post was last modified: 25-11-2012, 01:09 AM by spike2002.)
Yes you just need to alter the brake pipes exc I know a few members will proberly say don't fit it but from my experience the rear will lock up under hard breaking. Decent tyres or not. My phase 2 gti6 has abs and a compensator as standard. So there must of been a reason for it.
But then agen the compensator can seize so it doesn't work anyway.
If I was to do the swap on a phase 1/2 abs or non abs agen I personally would fit it.
Threads: 170
with winter coming up i dont fancy it locking up  . the compensator failed on mot but free'd it up.
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 115
26
Car Model/Spec: 306
I suppose its down to personal choice as i know some members have sed in the past its not needed. if you want to fit it or not is up to you. My opinion is for the lil bit of extra work fit it
I'm can guarante someone will be along shortly and say you don't need it tho lol
Threads: 23
Yep, me lol
As mentioned, my ph2 setup, has no abs, no rear compensator, and I've only ever locked it up twice, on track that is.
Threads: 115
26
Car Model/Spec: 306
So you agree that the rear will lock up then :p
Threads: 136
You don't really need the compensator as they just effect how much the rear brakes do depending on the weight in the back of the car.
The bit that would make a big difference and could cause the rear brakes to lock is the bias valve. You can buy aftermarket bias valves, then you can adjust them to suit you.
Threads: 26
Car Model/Spec: ZX Volcane
Brake compensators are dangerous if you're going low at all. Turn 306s very tail happy.
Threads: 115
26
Car Model/Spec: 306
(13-12-2012, 11:33 PM)Ollie Wrote: Brake compensators are dangerous if you're going low at all. Turn 306s very tail happy.
Never seen anyone post that before  you sure its not just how low you Irish lads lower them?
Threads: 208
60
Given 5 thank(s) in 5 post(s)
Tail happy in what way :? if you mean by braking mid corner............. Then dont lol not the best idea any way lol
Threads: 26
14-12-2012, 03:11 PM
(This post was last modified: 14-12-2012, 03:11 PM by Ollie.)
I guess it just depends how low you go, if you go very low, every time you touch the brakes its like pulling the hand brake.
Threads: 208
60
Thats prob because it so fecking low that it confusses the compensater as they arnt desgined to operate at that height. Along with the fact you have no movment in the beam
Threads: 26
(14-12-2012, 03:27 PM)puglove Wrote: Thats prob because it so fecking low that it confusses the compensater as they arnt desgined to operate at that height. Along with the fact you have no movment in the beam
Exactly! thus brake compensators are dangerous if you're going low!
Threads: 208
60
Meh i suppose. But besides the point as going that low is dangerous in genrel
Threads: 252
7
You say the phase 3 has a special ABS pump, so would swapping the pump also work the same as fitting the valve to the phase 3 axle?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 87
48
it's true . .ditch the compensator and if you emergency stop the back can lock up first . . ..i did it to avoid hitting a fcuking dog and ended up sideways . . . .  . . .you won't notice it otherwise, and i did look pretty cool so . ya know lol
