HDI axle onto XUD? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: HDI axle onto XUD? (/showthread.php?tid=8308) |
HDI axle onto XUD? - karl1989 - 24-11-2012 hi guys im changing my rear axle to a HDI axle and was wondering if there is anymore stuff that i need apart from handbrake cables?. are the brake pipes the same?. cheers karl RE: HDI axle onto XUD? - spike2002 - 24-11-2012 You going drums to disc? RE: HDI axle onto XUD? - karl1989 - 24-11-2012 ye mate. sorry forgot to mension RE: HDI axle onto XUD? - Daniel306 - 24-11-2012 Must be atleast 100 threads asking this question RE: HDI axle onto XUD? - spike2002 - 24-11-2012 The phase3 hdi beam won't have a brake compensator ![]() I went from drums to a hdi beam on my non abs 1.6 and didn't fit a compensator and the rear used to lock up under hard brakeing RE: HDI axle onto XUD? - Birk - 24-11-2012 Ph3 cars have a special abs pump so they don't have need for a compensator. And if your locking your wheels up with no abs, don't brake so hard and get better tyres lol My Dimma has no abs and I've only ever locked it up twice in 3 years of owning it ![]() RE: HDI axle onto XUD? - Ricky - 24-11-2012 Could always fit the compensator from your old beam if you don't have ABS. RE: HDI axle onto XUD? - karl1989 - 25-11-2012 i do have ABS ![]() RE: HDI axle onto XUD? - spike2002 - 25-11-2012 (24-11-2012, 11:40 PM)Birk Wrote: Ph3 cars have a special abs pump so they don't have need for a compensator. I was telling the op if he doesn't have abs and fits a beam with no compensator there is a good chance the rears will lock up. Under hard breaking eg emergency stops. Not normal driveing. My old car was a phase1 1.6 no abs and I fitted a beam off a hdi and didn't fit a compensator hence the rears locking up. As you say the phase3 doesn't need a compensator as the abs pump is different but being a phase 2 it will need the abs and a compensator to work as it should. Granted half the time the compensater is seized any way lol RE: HDI axle onto XUD? - karl1989 - 25-11-2012 ah ok. is it easy to fit the compensator if i get a axle without one? RE: HDI axle onto XUD? - spike2002 - 25-11-2012 Yes you just need to alter the brake pipes exc I know a few members will proberly say don't fit it but from my experience the rear will lock up under hard breaking. Decent tyres or not. My phase 2 gti6 has abs and a compensator as standard. So there must of been a reason for it. But then agen the compensator can seize so it doesn't work anyway. If I was to do the swap on a phase 1/2 abs or non abs agen I personally would fit it. ![]() RE: HDI axle onto XUD? - karl1989 - 25-11-2012 with winter coming up i dont fancy it locking up ![]() RE: HDI axle onto XUD? - spike2002 - 25-11-2012 I suppose its down to personal choice as i know some members have sed in the past its not needed. if you want to fit it or not is up to you. My opinion is for the lil bit of extra work fit it ![]() I'm can guarante someone will be along shortly and say you don't need it tho lol RE: HDI axle onto XUD? - Birk - 25-11-2012 Yep, me lol As mentioned, my ph2 setup, has no abs, no rear compensator, and I've only ever locked it up twice, on track that is. RE: HDI axle onto XUD? - spike2002 - 25-11-2012 So you agree that the rear will lock up then :p RE: HDI axle onto XUD? - Ben - 27-11-2012 You don't really need the compensator as they just effect how much the rear brakes do depending on the weight in the back of the car. The bit that would make a big difference and could cause the rear brakes to lock is the bias valve. You can buy aftermarket bias valves, then you can adjust them to suit you. RE: HDI axle onto XUD? - Ollie - 13-12-2012 Brake compensators are dangerous if you're going low at all. Turn 306s very tail happy. RE: HDI axle onto XUD? - spike2002 - 14-12-2012 (13-12-2012, 11:33 PM)Ollie Wrote: Brake compensators are dangerous if you're going low at all. Turn 306s very tail happy. Never seen anyone post that before ![]() RE: HDI axle onto XUD? - puglove - 14-12-2012 (13-12-2012, 11:33 PM)Ollie Wrote: Brake compensators are dangerous if you're going low at all. Turn 306s very tail happy. Tail happy in what way :? if you mean by braking mid corner............. Then dont lol not the best idea any way lol RE: HDI axle onto XUD? - Ollie - 14-12-2012 I guess it just depends how low you go, if you go very low, every time you touch the brakes its like pulling the hand brake. RE: HDI axle onto XUD? - puglove - 14-12-2012 Thats prob because it so fecking low that it confusses the compensater as they arnt desgined to operate at that height. Along with the fact you have no movment in the beam RE: HDI axle onto XUD? - Ollie - 14-12-2012 (14-12-2012, 03:27 PM)puglove Wrote: Thats prob because it so fecking low that it confusses the compensater as they arnt desgined to operate at that height. Along with the fact you have no movment in the beam Exactly! thus brake compensators are dangerous if you're going low! RE: HDI axle onto XUD? - puglove - 14-12-2012 Meh i suppose. But besides the point as going that low is dangerous in genrel RE: HDI axle onto XUD? - HDIkyle - 15-12-2012 You say the phase 3 has a special ABS pump, so would swapping the pump also work the same as fitting the valve to the phase 3 axle? RE: HDI axle onto XUD? - Mattcheese31 - 16-12-2012 it's true . .ditch the compensator and if you emergency stop the back can lock up first . . ..i did it to avoid hitting a fcuking dog and ended up sideways . . . . ![]() |
