wheel spacers advice??
Will the cyclones fit with the 406 brembos on? If so wot size spacers do you need?Also will the wheels stick out beyond the arches..thanks
Iirc 20mm spacers Smile
Naw nowhere near 20mm, i'm sure it's only 10mm or so needed!
so will they fit? does anyone know accually wot size you need?
10mm no chance you may get away with 15mm but from afew threads I have read it seems to be 20mm
