wheel spacers advice?? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: wheel spacers advice?? (/showthread.php?tid=8285) |
wheel spacers advice?? - Lisa306 - 24-11-2012 Will the cyclones fit with the 406 brembos on? If so wot size spacers do you need?Also will the wheels stick out beyond the arches..thanks RE: wheel spacers advice?? - spike2002 - 24-11-2012 Iirc 20mm spacers RE: wheel spacers advice?? - cwspellowe - 24-11-2012 Naw nowhere near 20mm, i'm sure it's only 10mm or so needed! RE: wheel spacers advice?? - Lisa306 - 24-11-2012 so will they fit? does anyone know accually wot size you need? RE: wheel spacers advice?? - spike2002 - 24-11-2012 10mm no chance you may get away with 15mm but from afew threads I have read it seems to be 20mm |
