81
Yo! Has anyone got a wiring diagram for the temp gauge thats in the centre console. I know some people run temp probes in their intercoolers etc so maybe it is possible to use the temp on the clock and keep it OEM.
Just another idea from Sam!
Threads: 130
82
Car Model/Spec: 106 GO-NAD
You'd need to get the resigance of the sensor in the mirror and make sure that you use the same resistance sensor in the ic. Or, put the sensor from the mirror in the ic....
Threads: 465
114
Car Model/Spec: Vauxhall
sam what temp range will you be reading at the intercooler?
as the clock lcd only has 2 segments anything over 99 wont read right
Threads: 130
82
pretty sure you wont see charge temps over 99 deg, might be wrong tho!
temp sensor in the wing mirror is a piece of piss to get at, its passenger side, little nipple under neath. pop the cover off and theres probably a couple of screws, or it prises off, i forget. either way, easy.
