Vibration
File Line Function
/global.php 961 eval
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
/showthread.php 1651 eval
Vibration
well iv recently had a bit of vibration through my pedals so i thought id check the engine mounts 1st finding this
[Image: Photo0091.jpg]
and this
[Image: IMAG0117.jpg]
so after repairing the hole and replacing with the baker BM mount pictured i took it for a drive. Its miles better but still have a little bit of vibration through the pedals so could it be the mount (because i know a few people have said about them) or is there something else worth checking?
Current cars
Subaru Impreza 2.0d - Daily
any one
Current cars
Uprated mounts can cause vibration, as they are stiffer Smile
Matt Wrote:Uprated mounts can cause vibration, as they are stiffer Smile
Twas what I was gonna say
Any vibration through the steering wheel?
a little bit. Its mainly on idle
Current cars
Exactly whats happend to mine... Still not fixed the hole mind.
dawson - iv put the mount in then the big washer underneath with 2 16mm nuts loctited into place it holds but still vibrates when idling
Current cars
Yeah wait till you here my bodge job.... Welded the washer to the chassis Like a pro. Now its knocking in gear changes and you can here it if you physically rock the engine.
Did you get intouch with the repair kit guy ?
Na mate i phoned bt kept ringin i wil try again. If your on the 6 site try pming him
Current cars
  Nasty vibration coming from the rear brakes johnny625 9 8,440 12-04-2020, 10:26 AM
Last Post: johnny625
  Strange vibration. decjhawes 12 7,550 21-04-2017, 05:22 AM
Last Post: Poodle
  VIBRATION- balancing and tracking done thealphanoob 0 2,044 22-04-2015, 10:13 AM
Last Post: thealphanoob
