turbo cleaning
turbo cleaning
before i fit my td04 turbo what and how is the best way of giving it an internal clean ?
You can clean the hot side and cold side housings when you take them off to clock it if you want
clock it ? lost me mate,lol.
You need to take it apart to turn the cold side outlet to point where you want it to
and the hot side off so you can rotate the cartridge to get the oil drain pointing vertically down
rite with ya,never own a turbo car before lads.whats the best cleaner
wire brush, very unlikely you will need to clean it as it gets hot and burns everything off anyway, and shite shoukldnt have been going into the intake anyway - if it has then the turbo will be f*cked.
the impellars are a bit dirty and their is about 1mm of play in the shaft.
Normal tbh.
