Torsion Bars.
Torsion Bars.
We had no luck with heat treated, pulled thread wheel studs when inserting in that hole in the middle, it pulled the threads in the end.
I think we ended up doing as maz-306-xs did and removing the swinging arm, resulted in as Ruan mentioned "on the floor"..... lol....
(11-10-2012, 01:12 PM)Ruan Wrote: Off the car is a f*cking nightmare... I ended up pulling the bolt through the eccentric washer by attaching the other end to a post in the ground and sledge hammering it... It's just a total pig to do..
The only *easy* way to do it is to use a hydraulic bearing puller, that's the only way I removed mine, but you can only get them out of one side doing it like that, so you have only 3 options, OEM, 10mm lower or on the floor... Heat and hammers are the only way... Slide hammers you may as well not even bother with, every time I just break the slide hammer...
+1 on the slide hanmers ruan they are full of fail when it comes to 306 torsion bars. Socket and bolt is the only way iv ever managed to get them out
(05-10-2012, 12:08 PM)kernow_joe Wrote: I have plenty of hammers so should be fine...
My mantra for most things Wink
  Torsion Bars/ARBs - Sizes and Sources anto 43 69,669 26-02-2019, 10:53 AM
Last Post: Mighty306
  Stubborn torsion bars Mighty306 12 7,261 09-06-2017, 08:07 PM
  Uprated torsion bars mossy1985 17 10,037 23-10-2014, 06:48 PM
Last Post: mossy1985
