Threads: 71
Car Model/Spec: 205 dt
picked up an omp strut brace yesterday for the great sum of £10 just not sure if I need extended bolts to fit them or not?
or will the standard ones do?
Threads: 63
26
Car Model/Spec: GTi6
The standard ones don't fit as Matt will tell you. Swampy sells them but there's also a seller on eBay that does them for a fiver.
Threads: 171
46
Swampy has a thread in the for sale section :-)
Threads: 71
didn't think standard would fit, should be able to get some down local tool place on saturday, don't suppose anyone knows what strength they should be?
Threads: 63
26
I tried that and they ended up making horrible noises when you turned. Check the eBay listing should give you an idea of what you need.
Screwfix. Bag of 50 for about a fiver!
Threads: 80
10
Standard ones will fit but apparently won't have enough thread on them to be safe. Just go down the local place and whip one out in the car park to get the same size, wouldn't bother messing around with swampy.
When you get the replacement ones make sure they are literally only 5mm longer then standard as otherwise they will touch the springs and you will get a lovely clang when you go from lock to lock (speaking from experience there!).
Serious.
(27-09-2012, 01:13 AM)samass Wrote: (26-09-2012, 08:58 PM)Niall Wrote: Liquid metal. tube of it for less than a fiver!
I thought you only used that on your engine internals?
Liquid metal works wonders at blocking holes.....fixing strut braces though.....hmmm will try this when I get mine instead of spending 4 quid on bolts!
