Help! My Window Fell Out!
Ok maybe the title is a bit of an over-reaction but...
Clearing the windows this morning doing the old wind-down wind-up again trick to get the dew off, drivers one did it without drama but the passenger window made a bid for freedom on the way back up!
A small grey clip at the top left corner was fired across the car park with some force.
I'm hoping that a repair is easy?
I've never had to do one on a 306 before! Are those little grey clips available separately?
[Image: Sig500x130.png]
There about £1.50 from pug or citroen mate just push on Smile
Team Doesn't own a 306
Happy days.
Part number anyone? Better order all the bits which have fallen off in the last 3 weeks.
Tilt lever
Arch liner
now Window Clip too
Oh and a replacement bulb for the dashboard.
Ha!
Also need the part number for this!
On the 306 waiting list.
sorry for hijacking has anyone had to replace cables in window gubbings?
[Image: J5hxCcC.jpg]
Cables are a nightnare! Far easier to replace the whole lot. I had to once and its impossible to get the cable on both ends of the runner
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Guys,
[Image: WindowClip.jpg]
Is it the Item number 2 I need?
0000922723
£1.80 exc. VAT. Just doesn't look right but this is the only picture I can find?
That's the one mate Smile
Yep that's the one. Good luck getting it in and having it run smoothly!
Cheers Kyle think il get full setup of one in scrappers and rivet new one in
These are a pita to do... try lubricate the inside of the seal when putting it on
S2 HDi >click<
154bhp
280lbs/ft
Thanks for the vote of confidence guys lol.
I have some silicone grease which is ideal for doing window rubbers etc. Is there a guide on doing this annoying little job?
Clip the new bit onto the glass. Wind the window almost down to the bottom, grab the seal/runner and yank it upwards so it comes out of the door. Slide it over the new part and back down into the door then press it all home into the B pillar. Simples
Door card off or on?
As Niall said mate, easily done with the door card on.
Door card on. With the window down, just grab the seal on the b pillar and pull upwards and out of the grove it sits in. Easy
(25-09-2012, 11:42 AM)CJ_Derv Wrote: Cheers Kyle think il get full setup of one in scrappers and rivet new one in
Trust me mate this is sooooooo much easier, from my experience i wouldnt even bother trying the wires
  20 Ltr jerry can Fuel filler hose fell in fuel tank!!!! Bunhead5565 13 4,107 12-08-2014, 08:36 PM
Last Post: HDIkyle
