81
My fans have all of a sudden completely stopped working. They were working at FCS as we forced them to come on for the rolling road. Several times in the past few weeks they havent kicked in and the engine has voerheated and the STOP light has come on.
All the sensors are plugged in so i guess the thing to check would be the plug (bottom passenger side?) and the relays? Any idea where the relays are located? D:
much love to anyone who can help!
81
yep. unplugging the air con temp sensor (green?) doesnt make it kick in as far as im aware!
81
does that not make the fans stay on all the time? D:
Threads: 130
82
Car Model/Spec: 106 GO-NAD
nope, turns your ac button into a fan switch
Threads: 171
46
What it does so is what amass said :-) means you can tell if its the fans motor that's f*cked or the wiring
You an figure shit out with it!
Ggaawwwddd saaaammmmmm
Threads: 171
46
15-09-2012, 11:40 PM
(This post was last modified: 15-09-2012, 11:40 PM by 4WayDiablo.)
The first one
As you kinda should have been able to tell by the washer bottle there...
Threads: 448
51
Just bridge the pins, make sure you get a good connection though. Mine kept falling out as the wire I used was too manly
81
ok bridged pins and it still doesnt work! D: Car is too low to get the jack under and ive got to leave for uni now! Hopefully there wont be any traffic jams D:
Threads: 30
Car Model/Spec: Peugeot 306 XRDT
Might be relee behind the peugeot emblem front bumper going loose check that out.
Threads: 30
My fans diddtn work a couple years ago and engine heating upp so i removed
Peugeot emblem and pushed 2 relays back again and it worked again.
81
hmmm okay. i cant actually jack my car up as its too low. I need somebody too lift the car up via the arch to actually get the jack under D: When im home from uni ill have to get somebody to help. Luckily traffic hasnt to bad and i get the loser cruiser (bus) into uni if the traffic is bad! D:
Threads: 171
46
Scissor Jack then trolley jack for low entry :-)
81
right so if the fans arent cutting in at all so... things to check?
relay which is located on the bottom left of the fan unit?
fuse? not sure where as in the haynes its tied into other things which seem to be working!
Threads: 164
25
Car Model/Spec: Gti6
Stick a.millimeter across all the fuses anyway might find one has still gone?
Threads: 170
put your heaters on when driving that should keep the temps down for now
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
81
ok right myself and Mooey65 had a quick look a the fans tonight. The bottom green relay had a leg completely corroded! Fitted a new one but no change. We removed the brown coolant plug to turn the fans on and we could hear the relay but the fans still didnt come on. Any ideas? Loose/corroded bottom plug?
