Threads: 170
5
Car Model/Spec: xud 1.9 dturbo
14-07-2012, 08:17 PM
(This post was last modified: 14-07-2012, 08:17 PM by karl1989.)
Not a good update. car failed MOT today . will be going back for retest on saturday. my failures
Nearside Headlamp aim too low (1.8) - free fix
Offside Headlamp aim too low (1.8) - free fix
Brake load sensing valve seized (3.6.E.3) - free fix
Nearside Front Coil spring not correctly located (2.4.C.2) - fixed
Offside Front Coil spring not correctly located (2.4.C.2) - fixed
Nearside Front suspension has excessive play in a lower suspension ball joint (2.5.B.1a) - to do
Nearside Front Suspension arm ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt (2.4.G.2) - to do
Offside Front Suspension arm ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt (2.4.G.2) - to do
Offside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1) - to do
Nearside Rear Rear brake binding (3.7.A.5a) - to do
Advisory Notice issued
Nearside Rear Brake pipe slightly corroded (3.6.B.2c)
Offside Rear Brake pipe slightly corroded (3.6.B.2c)
some pictures of today
at garage
pics of there cars in the garage
BEST PIC
the suspension change, got the gf to do the drivers side .
plans. get mot and tax then raise back end
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Threads: 59
3
Car Model/Spec: 306 D-turbo
They aren't to bad them fixes should be easily done in a day or two. Not long now then it's back in the road for you.
Threads: 117
21
Car Model/Spec: needs bwarrrp.
Given 1 thank(s) in 1 post(s)
dont look to bad. you need to get some challengers back on her imo.
Threads: 208
60
Given 5 thank(s) in 5 post(s)
Nothing to bad there atall mate. Alot but nothing major, id be quite happy with that as nothing painfull .there and tbh a few things that you should have picked up before hand springs/tyre.
Also im with kingy, challengers looked better on this IMO
Threads: 170
5
im on the look out for some more challengers .
got the ball joints today so car should be ready tomorrow to re book the MOT
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
5
17-07-2012, 11:31 PM
(This post was last modified: 17-07-2012, 11:31 PM by karl1989.)
well here is todays jobs. didnt help not having the right tools but managed what i could today.
Brake load sensing valve seized, wd40 and abit of a wiggle and she freed up
Nearside Front suspension has excessive play in a lower suspension ball joint, the ones i bought didnt fit so had to get some more before the place shut. then to find my wheen bearing on its way out
Offside Front Suspension arm ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt, done
Nearside Rear Rear brake binding, done cable was easy. getting the rest back together was a pita
Nearside Rear Brake pipe slightly corroded, gf cleaned them up with copper grease
Offside Rear Brake pipe slightly corroded, gf cleaned them up with copper grease
will be going to finish it of tomorrow after work.
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
5
car nearly done now. went over after work for abit. got another hub from the breakers and the bearing is perfect no play at all. took her for a spin round the block and seemed to pull quit well so the rear brake binding must have been really bad and slowing the car down. going to sort a time for the retest tomorrow as i didnt have time today then saturday morning adjust the lights and get the wheen but back on with the good tyre .
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
5
22-07-2012, 11:21 AM
(This post was last modified: 22-07-2012, 11:22 AM by karl1989.)
well the car has a 12month ticket and 6months tax . drove to the MOT station with some epic noises got back home jacked up the car to have a look and some little twats undone my wheel. was on by a few threads so could have fallen off. but all sorted out now . will get piccys later
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
5
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 186
38
Car Model/Spec: MG ZR VVC
Given 21 thank(s) in 19 post(s)
Your two rear ends look like they both need to meet in the middle lol
Good job on getting mot though, looking forward to seeing/testing it again a hdi front mount
Threads: 170
5
now boosting 20psi . the actuator popped of the turbo lol.
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 9
19
Given 3 thank(s) in 1 post(s)
(22-07-2012, 06:24 PM)lolsteve Wrote: Your two rear ends look like they both need to meet in the middle lol
Exactly what I was thinking, they look like they are trying to balance each other out
Glad you got the MOT and the boost issue sorted matey
Threads: 170
5
im getting the back raised up level to the front and my mate dropping his down. cheers mate so am i. can come to meets now.
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
5
well no big updates yet apart from the passenger brake line decided it dint want to work anymore so went and bought one this morning and fitted it. feels nice to have brakes again
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
5
not much of a up-date yet again but gave the car a polish and fitted a new bottom arm today and it feels so much better. the steering wheel doesnt throw its self about anymore . will upload pics through the week.
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
5
11-08-2012, 06:51 PM
(This post was last modified: 11-08-2012, 06:51 PM by karl1989.)
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 226
24
Car Model/Spec: A3 TDi
Everyone loves polish! Looks nice man
Threads: 5
love this car
how low is your rear beam
Threads: 170
5
well got a quote on bumper £90 painted or £140 with the number plate smoothed
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
5
not updated much recently. noticed water coming in my boot the other day. stripped it all out and found out its because i have no rear arches so i will be going to get some. on the good side the rear passenger panel is solid . also got a twin exit powerflow back box witch should be fitted tonight so will upload pics tonight .
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
5
30-08-2012, 11:52 PM
(This post was last modified: 30-08-2012, 11:53 PM by karl1989.)
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
5
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 186
38
Shiiiii...oh dear, any idea how much diesel you lost?
Threads: 170
5
(08-09-2012, 11:03 PM)lolsteve Wrote: Shiiiii...oh dear, any idea how much diesel you lost?
not sure hopefully not alot. ive just filled it up to go to sheffield tomorrow.
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 186
38
Ah ok, good luck think I got some small jubilee clamps about somewhere if you wanting one
Threads: 170
5
(08-09-2012, 11:18 PM)lolsteve Wrote: Ah ok, good luck think I got some small jubilee clamps about somewhere if you wanting one ah cheers mate. if i cant find a jubilee al give you a text
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
5
well today as been a oright day. had a drive over to jenkosowls to do the cambelt. he done a spot on job too. will send rep when you comment mate. also now got gov-mod witch is very nice . thats is all
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
5
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 8
Car Model/Spec: ventian green p2 d-turbo
really do love your yolk karl still dont know weather i like the challengers or nimrods the best on it though
Threads: 170
5
(11-09-2012, 06:11 PM)jonny1.6 Wrote: really do love your yolk karl still dont know weather i like the challengers or nimrods the best on it though cheers mate. it will look abit different soon. i prefer challengers. regret getting rid now
Ph3 perv cab heaven
Black ph1 XUD died
