Threads: 119
15
Car Model/Spec: Ph1 Diablo DT
you welding the rear suspension up as youl lose tension in the chain when you sit on it
www.prestige-auto-care.co.uk
Threads: 102
9
needs a drop, be funny to see it do burnouts.
81
would it not have been better to mount the motor on the bottom of the frame so then you can keep the suspension?
Threads: 52
Car Model/Spec: Ph2 Dturbo
Motor was to hard to line up if it ws mounted at the bottom and the original cranks and gears were fuked that why it wad free
Damn you. I was going to do this with a old 5hp lawn mower engine I had!
Threads: 169
91
I can vouch for the fact that a starter motor can run for at least half an hour on a Bosch super battery. Just make sure your around when it's cranking...
/selftroll
Threads: 62
10
That has got a trip to casualty written all over it.
HDi Owner for 200k/9 years
