Stage 1 map?
Stage 1 map?
#31
138.7 on a stage one really is a lot, i'm actually suspecting the dyno... Don't suppose anyone else got dyno'd that day..?
Ah now I see where you're coming from Ruan, it'd certainly be an interesting experiment. What kind of injections pressures is Darren running on his beast...? That's virtually the same engine, should be comparable in a general sense at least...
The only other factor i can see is pumping losses, although that's an easily calculable value, no?
If it's my HDi you're all thinking of here (dyno'd just over a week ago) then it did hit these figures but Poodle is most likely right......even TB who wrote the map suspected the same.......he reckons it's more like 130BHp
Even then it's still a bit of a strange one as other cars that ran the following day at the RR meet produced figures that seemed accurate and that were expected.
