Lion
Taken my bonnet badge off, want to spray it all black and the lion green, can
I take the lion off so it's not messy? Tried lever it off with a knife but it just isn't happening.
Its bolted on. Theres just one nut to take off I think.
Open the bonnet and look underneath the badge.
I've taken that off. Just want to take the silver bit off the actual badge to paint it
Is glued on I did the same as with head lights stick it in the oven, lightly prised it out with a Stanley blade
[Image: signiture.jpg]
Ok gareth7 he knows.
I just pulled mine apart, it's glued and pinned.
Yeah as matt :-) just pulled it off. Might break it though lol
yeah thats why I heated mine up, not sure if it made a difference or not
i heated mine and drilled out the sprews and still broke it. Id suggest just masking it off. I did that on mine and its a really impressive job seeing as it took 15 minutes!
Use a drill......very carefully.......10 second job
don't be a heavy handed twat and heat it and gently lever under each point that its held, easy to see from the back where the fixing points are, then you can do a proper job of it, same goes for the surround
Just sprayed it all black was too much of a ball ache hahaha
