Threads: 9
19
Given 3 thank(s) in 1 post(s)
There are a few variations, the bottom hose clip can be either a metal retaining clip or the plastic twist lock design, make sure you get the right one as it will not fit if you get the wrong one and the bottom hoses are nearly £40 from pug!
the other variations are with or without inbuilt header tank which is normally ph1 has inbuilt tank, ph2 has a separate header!
Or scrapyard and Henry Hoover tubing to convert between the hose types.
FTW!
(16-05-2016, 10:45 AM)Toms306 Wrote: Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in. ![Wink Wink](https://www.306oc.co.uk/forum/images/smilies/wink.png)
