01-08-2012, 11:07 AM
Going to pick up a set of phase 3 rub strips for my phase 2 Are they just the little plastic clips on to the door? And are the holes in the same place for the clips? Thanks
Rub strip question
01-08-2012, 11:16 AM
Yeah lots of plastic clips. I didn't break one when talk g mine off it really isn't hard they usually stay in the bodywork when taking the strips off so you may need a small screwdriver to poke the grips in the back of the clip
01-08-2012, 11:22 AM
Sound 4way You know if phase 2 and 3 are the same?
01-08-2012, 11:31 AM
Should be yeah, I've seen it done many a time before some hole may differ slightly but still go on fine
01-08-2012, 11:37 AM
Thanks repped
01-08-2012, 03:26 PM
Depending on what wings you have on yours, the trims might not line up properly. If your wings have 4 holes then itll be fine, but if theres only 2 you might need to glue them on
01-08-2012, 05:06 PM
Yes ph2 are the same as ph3 apart from the wing, the small one sits a tad low, I just broke out the clip holders the glued the plastic clip in the correct place on the back of the rub strip, simples
