Rub strip question - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: Rub strip question (/showthread.php?tid=5271) |
Rub strip question - Bananalad - 01-08-2012 Going to pick up a set of phase 3 rub strips for my phase 2 Are they just the little plastic clips on to the door? And are the holes in the same place for the clips? Thanks
RE: Rub strip question - 4WayDiablo - 01-08-2012 Yeah lots of plastic clips. I didn't break one when talk g mine off it really isn't hard they usually stay in the bodywork when taking the strips off so you may need a small screwdriver to poke the grips in the back of the clip RE: Rub strip question - Bananalad - 01-08-2012 Sound 4way You know if phase 2 and 3 are the same?
RE: Rub strip question - 4WayDiablo - 01-08-2012 Should be yeah, I've seen it done many a time before some hole may differ slightly but still go on fine RE: Rub strip question - Bananalad - 01-08-2012 Thanks repped
RE: Rub strip question - Connor - 01-08-2012 Depending on what wings you have on yours, the trims might not line up properly. If your wings have 4 holes then itll be fine, but if theres only 2 you might need to glue them on RE: Rub strip question - puglove - 01-08-2012 Yes ph2 are the same as ph3 apart from the wing, the small one sits a tad low, I just broke out the clip holders the glued the plastic clip in the correct place on the back of the rub strip, simples
