05-12-2011, 10:01 PM
Governor shimming guide
Firstly I removed the minimum and maximum throttle arm travel screws. One is on the front of the pump and the others on the back. Both held in place by a 10mm locknut, and removed using a flathead screwdriver in the end of the screw. The front one is circled below:
Next up you want to mark the position of the throttle arm in relation to the splined throttle shaft. You should scratch a line on the throttle arm in line with the indent on the top of the shaft, as you can see I did in the photo below:
Now you can remove the throttle arm. This is held on with the 10mm nut around the splined shaft. As you undo it, keep even pressure on the throttle arm to hold it down, this just stops it flying off and breaking/getting lost. When the nut is removed you should be able to lift the throttle arm and the spring around it off, with a little bit of wiggling.
Now find the max fuel adjustment screw, located here:
Slacken off the 13mm locknut, then wind the screw out almost all the way, so its just hanging on by a thread or 2. This puts less tension on the gov shaft, and makes it easier to remove.
Now you want to remove the main 4 Allen/torx bolts that hold the top and bottom of the pump together. These should be relatively easy to find, one in each 'corner' of the pump. Remove all of these and now handle the pump very carefully, as the top is loose but still connected to the internals of the pump.
If you gently wiggle the top of the pump up, the splined throttle shaft should fall out of the top of the pump (it may need some persuasion, but don't be to forceful!).
Once this is out you only have to remove the small spring connected to the cold start lever. This should just slide off with the help of a little screwdriver. Now the top of the pump should just pull away, obviously be very careful removing it, just in case anything gets caught etc. Once the top of the pump is off, you should be left with this:
Red arrow is where the gov assembly has to slide into, blue arrow is where one end of the cold start spring hooks onto.
You should be able to clearly see the governor assembly (riveted to the splined throttle shaft) and now you can remove it. If you look where the shaft sits on the bracket inside the lower part of the pump, you should see a little flat section, which you will need to rotate, and then wiggle to remove it from the bracket.
One it is removed it should look like this:
From left to right, Main spring (the one you need to shim), Intermediate spring and then the idle spring.
Now you need to remove the shaft and springs from the cradle. To do this, compress the springs slightly, and it should pop out. Be very careful doing this as the gov' shaft and cradle are both very brittle and if they break you will need to source a new one, not cheap!
Now for the tricky bit.
You now have to remove the small circlip on the 'main spring' end of the shaft. Again compress the spring slightly and then using either a small screwdriver, or witchcraft, remove the circlip (be very careful and don't lose it, as its very likely to ping off and make a bid for freedom!) then slide off the spring seat and main spring.
Now you need to find a suitable 'shim', either 2/3 small washers, a small nut, whatever! As long as it's not made from plastic/wood or is way too big etc. I used a small nut, and 1 large thin washer on mine, see below:
See the small nut and large thin washer in the main spring section.
Shimming it around 3/4mm is about the average, much more and you will struggle to get the assembly back together and in the cradle. Much less will just have less of an effect.
When you are happy with the shimming, you can put the main spring back on, and then the main spring seat. Now you have to compress the spring to get the circlip back on. Again being very careful not to let go/drop it all, as it will all go flying and get lost!
Once the circlip is back on, double check everything is in the correct order, and put the assembly back into the cradle, again compressing the assembly and being careful not to snap anything.
Now you have done all the hard stuff, re-assembly is simply the reversal of disassembly, but here is a quick run though just to make it easier:
- Wiggle gov shaft back into bracket in lower part of the pump
- Re-connect little cold start spring
- Push splined throttle shaft back into the top part of the pump
- Let the top section carefully fall into place (If it wont go back down smoothly and easily DON'T force it, something has either moved/got stuck. The throttle shaft was quite tricky
- When its in place and your happy, put the 4 main bolts back in, and tighten up.
- Re-fit throttle arm ON THE CORRECT SPLINES! Make sure the notch on the shaft lines up with the scratches you put on the throttle arm earlier.
- Tighten throttle arm down
- Re-fit min throttle arm travel screw at the back of the pump
- Dispose of max throttle arm travel screw (Or keep it as a spare for the MOT...)
I think that's everything!
Dan.
Dan.
