Threads: 63
26
Car Model/Spec: GTi6
14-07-2012, 08:09 PM
(This post was last modified: 14-07-2012, 08:10 PM by vlj.)
Threads: 48
2
Glad to see you made it back ok. My shed really is a tip its even worse now, needs a major clear out. Theres so much here that we forgot to put in the car.
Threads: 63
26
(14-07-2012, 08:25 PM)Fozzy Wrote: Glad to see you made it back ok. My shed really is a tip its even worse now, needs a major clear out. Theres so much here that we forgot to put in the car.
If I had the time to help clear up I would have! I'll see you again later in the week. Definitely need that heater matrix...
Threads: 48
2
Its 99% my mess anyway. Yeah might take the other matrix out of the bottom car just so you have a selection to chose from
Threads: 63
26
Before I went to work today (up at 4 45 working on the car til 7 45... dedication!!!) and after work I set about changing the looms over and installing all the other wiring for CL so on so fourth.
At present the loom inside the car is stripped down to bare basics so I'll need to remove that and replace it with a complete loom, then stick in the heater matrix and can put the dashboard back in with the complete loom.
There's a lot more to get done before my already postponed mot.
Thankfully mechanically the car is completely sound. Cambelt will be changed once the car is officially road worthy.
Got 4 days off now so expect considerable progress
Threads: 541
124
(15-07-2012, 09:32 PM)vlj Wrote: Got 4 days off now so expect considerable progress
Cant wait to see this
Threads: 63
26
Threads: 63
26
Threads: 448
51
whats tapping in that vid?
Threads: 63
26
(16-07-2012, 05:04 PM)Matt Wrote: whats tapping in that vid?
Almost certainly not the engine
Threads: 448
51
tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap
you sure?
Threads: 63
26
(16-07-2012, 05:34 PM)Matt Wrote: tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap tap
you sure?
It was a group of tap dancers in the street.
Threads: 448
51
ahhhhh that explains it then! when is this on the road then?
Threads: 63
26
16-07-2012, 05:53 PM
(This post was last modified: 16-07-2012, 06:01 PM by vlj.)
Threads: 48
2
think you need a Decat for that seat
Threads: 541
124
Its Eds car, you can hear it tapping all the way from Bognor
Trololololol
Threads: 448
51
I think I would have kept it stripped lol. As soon as I'm back on the road I'm feeling mini meet?
Threads: 63
26
(16-07-2012, 06:20 PM)Matt Wrote: I think I would have kept it stripped lol. As soon as I'm back on the road I'm feeling mini meet?
Sounds good to me! We'll coerce Curt out too so there's 2 of Fozzys old cars out :p
Threads: 48
2
I did suggest this, think of the weight saving, ide already done the hard work and got rid of all the useless things like electric windows central locking. even offered my cut down dash.
Threads: 63
26
(16-07-2012, 06:25 PM)Fozzy Wrote: (16-07-2012, 06:20 PM)Matt Wrote: I think I would have kept it stripped lol. As soon as I'm back on the road I'm feeling mini meet?
I have realised I can't be bothered making it all fit etc considering going back to the stripped loom but including audio into it as I don't think I could go without.
Threads: 48
2
Threads: 208
60
Given 5 thank(s) in 5 post(s)
Alot of work to be done there mate, good luck i will be watching
Threads: 71
4
Car Model/Spec: 205 dt
you don't need a stereo in a 6/rallye you have engine porn to listen to!!
Threads: 130
82
Car Model/Spec: 106 GO-NAD
damn dude, progress much!?!
you're a machine! i woulda got bored long ago, taped the clock to the steering coloumn, and stuck my ipod and some speakers in there for audio!
Threads: 63
26
I feel like smashing my head against the wall. The hazards light switch on the complete loom looked stripped right back and I already had the idea in my head that I wanted the stripped loom in just to mot it... so start taking apart dash and loom again ready to transfer the stripped in and pull back carpet to disconnect rear, and there is the hazards box connector  what a waste of time
Threads: 63
26
Threads: 138
72
Car Model/Spec: Mincebus
WOW this is going quickly! Nice one on getting one already buddy :-)
let me know when you get it fixed, we should sort a mini-meet when Matt's finished de-tappifying his valley
Astor 'X' 4 GTi6- 6 - SOLD!
Threads: 63
26
(17-07-2012, 05:18 PM)Ed Doe Wrote: WOW this is going quickly! Nice one on getting one already buddy :-)
Fixed? There's nothing wrong with it! Its ready for an MOT now, everything needed for it is in.
Meet sounds good to me, we'll leave the tapping to you
Threads: 448
51
Well hopefully it's going to be fixed on the 28th  VLJ come on down  I'm only down the road anyway
Threads: 289
92
Car Model/Spec: Phase 17 R26
Given 1 thank(s) in 1 post(s)
That's really good progress mate! I'm sure I'll see you on the weekend of the 28th at some point...I'll be coming to Bognor with Kim before heading to Matt's, so even if you're not coming I'll come over and say hi for a bit.
