Threads: 170
just got my new drop links deliverd so fit them and prep for the m.o.t
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Threads: 9
19
Given 3 thank(s) in 1 post(s)
Sorry I couldn't help more when Kyle rang, I was just going out...........However my first question pretty much was "are you sure the release fork is behind the bearing properly"
Hope all goes well with the MOT
Threads: 170
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
havent been any updates recently but there is some coming. got a FMIC coming next weekend for a offer i could'nt refuse. hopefully all will go well and i will be fitting it soon as i get it
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 448
51
Looks tidy that!
Threads: 170
think i will re-route the pipe work. not how i want it to be set up but ye its not bad
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 3
7
Looks alright that pal!  When's mot?
Threads: 170
Alee83 Wrote:Looks alright that pal! When's mot? when i book it lol. still need to tighten hubs. havent been to do anything with the car for about 3 weeks.
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 208
60
Given 5 thank(s) in 5 post(s)
Those spring were fu*kin rough. who ever done that should be shot
Threads: 170
puglove Wrote:Those spring were fu*kin rough. who ever done that should be shot ano mate. worst part was i let the gf drive the car like that but i didnt know they was like that. anything could of happened.
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 208
60
karl1989 Wrote:puglove Wrote:Those spring were fu*kin rough. who ever done that should be shot ano mate. worst part was i let the gf drive the car like that but i didnt know they was like that. anything could of happened.
Madness mate, why do it?? for the sake of £50 for some gmaxx 60mms
Whats the score with tis then mate? is it your now? studturbos old one?
Threads: 170
god knows. the lad that got the green 306 (my car) origionaly bought it with the suspension like that from barnsley about 3 years ago. he a mot tester  didnt even tell the previous owner or me about them :evil: . im getting some springs for it that actually fit. the ones that was on didnt even need clamps to take the srings of they was no tension at all. no mate studturbo came over in his car to give me a hand thats all.
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
well got the FMIC today. had a check and all looking good. needs a clean but im on it. also pipes have already been beaded and has been tapped into for the boost gauge  . will be fitting this soon. also got a derv doctor dump valve with it so keep checking this thread  .
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
couple of pictures of the fmic.
cooler
inlet. will be cleaned up before fitted
dump valve
pipes
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
well the fmic will be fitted at the weekend aslong as the weather stays nice. await pics people
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
30-06-2012, 05:37 PM
well the FMIC is on hold thanks to the yorkshire weather  . try get it fitted tomorrow. managed to fit the track rod ends and get abit of copper grease on the brake lines before the rain started.
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
08-07-2012, 05:08 PM
(This post was last modified: 08-07-2012, 05:09 PM by karl1989.)
UPDATE
well FMIC is on  . well most of it. started of by arron_DT picking me up will rep when you comment mate. so anyway went over and cracked on with waht we could. did start to rain now and then but waited for it to stop  . heres some pictures
FANS
NO FANS
BROKEN FANS
COOLER OFF
RANDOM BOSCH PIC
MANIFOLD UNBOLTED AND OUT
NEW MANIFOLD
SOME PIPES ON
PIN
LAST PIC. HOW THE COOLER WILL BE MOUNTED
All need to do now is cut the slam panel abit with a grinder to get the drivers side pipe up to the top and mount the cooler properly and she done  .
comments welcome
cheers guys
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 33
Good lad get it done pal
STAGE2 XUD DEAD ATM ENGINE REBUILD
GARRET T2-BOSCH PUMP-GROUNDED LDA PIN-GOV MOD-FMIC-STRAIT THRU STAINLESS EXHAUST SYSTEM
COMING SOON TD04
Threads: 170
I am dont worry
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
10-07-2012, 08:31 PM
(This post was last modified: 10-07-2012, 08:31 PM by karl1989.)
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
11-07-2012, 07:03 PM
(This post was last modified: 11-07-2012, 07:04 PM by karl1989.)
well my car is now on the database as insured  . Booking MOT tomorrow. Also found a dturbo been broke so im taking the day of tomorrowim taking the radiator and fitting it that and also the morettes, maybe the the stainless exhaust so mine might be up for grabs.
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 208
60
11-07-2012, 07:20 PM
(This post was last modified: 11-07-2012, 07:23 PM by puglove.)
Top job bud. I like looking at these pics gives me some options on how to do mine when it comes to it. Though id route the FMIC to inlet pipe slightly different.
Is there any reson from the inlet you couldnt turn the 90 down and go towards the right of the car behinde the Rad rather than across the top of the engine bay?
EDIT: Good work mate!
Threads: 170
(11-07-2012, 07:20 PM)puglove Wrote: Top job bud. I like looking at these pics gives me some options on how to do mine when it comes to it. Though id route the FMIC to inlet pipe slightly different.
cheers mate. only reason its routed this way is because this is how i bought the kit so limited to other routes. need some more piping really so i can move it about
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 208
60
Ah right cool, was just checking, its hard to explian via writting but i think you could fit it the way im thinking with what you have.
Looking at the car from the front.
90* pipe from the inlet turn to face down.
Next 90* pipe to connect to that then turn right
Next 90* pipe turns out to the front and on to the cooler.
Looking at yours thats the way i think im going to do it but im going to use a STD manni adapter.
Good to hear it will be back on the road soon aswell, i do like this purly because you dont see many ph3's modded in this colour. (i Know its a ph2 but ph3 look) I would like to spray my 6 this colour for the fact that they never did them and its an OE colour.
Threads: 170
(11-07-2012, 08:00 PM)puglove Wrote: Ah right cool, was just checking, its hard to explian via writting but i think you could fit it the way im thinking with what you have.
ah i know what you mean mate. need some more hoses as mine are all straight. why dont you go for the manni i have?. meant to be better flow. cheers mate i was thinking of putting a ph2 bumper back on but not 100% sure yet. ye the colour is fairly rare id say.
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 186
38
Car Model/Spec: MG ZR VVC
Fmic before MOT, fantastic priorities  aha glad to see it's progressing though hopefully will get to see it/help out with repairs when I come back up at end of aug
Threads: 170
12-07-2012, 11:21 AM
(This post was last modified: 12-07-2012, 11:21 AM by karl1989.)
(12-07-2012, 07:07 AM)lolsteve Wrote: Fmic before MOT, fantastic priorities aha glad to see it's progressing though hopefully will get to see it/help out with repairs when I come back up at end of aug
its got to look good for MOT lol. yeye let me no when you free mate. will meet up
car is booked for MOT on saturday at 9am  . also got another radiator so going to fit that today and give the car a bath. pics up later
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 170
well had a sh*t day. radiator was different so had to take it back to swap for another and they was all different. another 4 breakers yards and still no joy so had to get some bar leaks for a temp fix witch sorted it out. so having to go finish what i was meant to do tomorrow ready for saturday morning. will get pics up tomorrow
Ph3 perv cab heaven
Black ph1 XUD died
