Matts rallye project. operation derust
Possible fail
And it's a net from egay
http://i35.photobucket.com/albums/d196/m...9d0ffc.mp4
Damn you, mine is getting stripped within this week.
Had to beat you too it. Out of interest mate what weight have you lost from the front end? I want to start reducing this too, but have no idea where to start. Stripped bianca fwends!
Youre gonna have to spend some money to start losing much from the front end of the rallye bud. Poly windows, grp/carbon panels, etc. Could lose the dash...
I'm doing a cut down dash, loosing the glove box etc, going to do all lightened pullies and flywheel, going to strip the loom of excess wires, just looking for things that are unnessary lol, already running my washer bottle only a third full an going to relocate the battery Big Grin
Smaller washer bottle, single lighter fan, alot of plastics removed, bonnet lining removed, stick on number plate etc
Ive lost the fogs and AC but thats no use to you.
Ive removed some useless bits of hose and trunking and plastics
Then coming up is stripping all the unused plugs off the loom and probably electric PAS.
I've lost the lining, already have the Rallye single fan, may look into the weight difference. What bottle did you put on then? Was going to loose arch liners but they are too valuable too corrosion prevention. Gas lifters will be going, also trucking too, I've thought about electric abs but can't afford to do it at the moment.
Next steps to the weight loss is
Trimmed loom
Cut down dash
Polycarbonate windows (eventually)
C/l removal
Trimmed dash loom
Sunvisers out
Single skinned bonnet
Group buy on Fiberglass bonnets? they're not that expensive, but it would be nice to save some moneys...
Haven't looked into them, how much are they?
http://www.spoox.co.uk/catalog/index.php...02cff6c71a
£175, but probably less than 1/2 the weight of a standard one
Fibreglass bonnet and aero catches = winning!
(05-08-2012, 12:29 PM)Matt Wrote: Possible fail
[Image: 2e9d0ffc.mp4]
My god this fails hard! Can't post it on here due to fail. Unless someone quotes it, then the IMG code is there!
Matt is this video foot flat on the floor in 2nd? Huh
I might eventually be interested in a fiberglass bonnet too.
My washer bottle is a ebay kit car one. Its 1.25l and comes with a built in pump thats really powerful, i get a better spray out the small one than the pug one and the bottle itself is less than half the weight of the pug one IIRC. Only cost a tenner.
I might put up my weights thread later tonight or tomorrow.
Oh if your loosing the visors what colour sun strip are you going for. Im stuck between black or white. Mine will be another 10" cos i sit so low in buckets.
Foot flat in 3rd Tongue thought it would be interesting to see what is was like, and for the noise lol
Linky Dum? Does it fit straight? As I know you said you fitted it wonky lol.
Sinstrip? Who needs a sun strip when I have sunglasses Tongue haha
glad shes all up and running bud, now get to hooning lol
[Image: SDC10442-1.jpg]
Give her a service tonight then out for a hoon Smile
This one is very similar, and the cheapest version of it on ebay. The one I have on mine and had on the old HDi seem to not exist any more.
http://www.ebay.co.uk/itm/WINSCREEN-WASH...1045wt_932
Its not a direct fit. It needs bolting to a flat surface. Im gonna move mine to behind the ECU tray and bolt it to that.
Currently mine is just sitting on the O/S inner wing where the filler for the OEM bottle should be.
It also means you can remove alot of washer hose and save weight that way.
If your at ace cafe on the 20th you can have a look if you want.
Sweet cheers mate.
Just serviced the bitch. She ceases to amaze me! Sump bolt barley hand tight, no washer, oil filter seized solid. Oil absolutely reeked.
Fuel filter to do still. But that can wait till after tea
I'm still dubious about the positioning of that washer bottle, you know... ECU + washer fluid = bad day... Undecided
Glad to see you finally serviced her mate.
Good work mate. Mine is now stripped at the back.
Me and Poodle found out you can remove the back bit of carpet without actually removing the front seats or even unplugging them.
Back 2 seat bolts off the fronts, all 4 of the rear seat front mounts, lift the door seal and get the 2 screws out the rear of the center console and give it a good tug backwards. Then use a knife to cut a slit for each set of seat plugs and a slit for the handbrake.
Check my thread in an hour or 2 and ill have up weights for a load of other stuff that I can see youve got to remove.
(06-08-2012, 10:04 AM)Matt Wrote: Foot flat in 3rd Tongue thought it would be interesting to see what is was like, and for the noise lol
Ah right fair do's i was thinking 2nd for some reson, no wonder it was a little slower than what i would expect,
Sorry for spamming your thread matt but i have to say it,
@ Dum-Dum: Dont do a white sun strip it looks cack with the black rubber around it, Theres a quick silver around my way with a silver one and it just looks gay with the window rubber.
haha i hate white sunstrips too. sweet cheers for that dum.rear carpet will be coming out on saturday Smile
Right, I've spoke to spoox about bonnets, apparently they're done at cost price, so no discounts available Sad
But to be fair, they are cheap anyway at that price!
i thought that, they are not that badly priced.will be on my list of things to do.
Thats a shame. Are they de-badged or do they have a hole for one.
I wonder what the lightest headlights are?
Morretes?
Anyone fancy weighing a couple of different types of headlights?
EDIT: They're debadged mate
debadged as adding a badge will make it heavy lol
but... filler to smooth the grille adds weight!
what grill? Tongue or use one of those fiberglass jobbies
(06-08-2012, 10:09 PM)Matt Wrote: what grill? Tongue or use one of those fiberglass jobbies
I has smoothed fiberglass grille.
  306 rallye trackday project twangy 383 349,378 19-03-2020, 05:12 PM
  Matts cheap cherry rallye Matt-Rallye 15 15,073 02-01-2018, 08:45 AM
Last Post: Matt-Rallye
  Matts Cherry HDi Dturbo. Project Stage 1+ & tidy up. Matt-Rallye 29 26,590 10-05-2017, 12:49 PM
