17-09-2013, 10:30 AM
Excellent news...! Lots of win.
![[Image: Sig3_zpscd005eb1.jpg]](http://i1099.photobucket.com/albums/g385/alee83/Sig3_zpscd005eb1.jpg)
THE_Liam - Diablo Phase 2 DT - To break, sell or crack on?
17-09-2013, 12:17 PM
I'm gonna give it a damn hard tune when I have a day off, its only boosting 15psi at the moment but that's with the restrictor on the max fuel, got a new screw so I can whack it up and fit my ground LDA pin, then chuck it on't dyno running veg. I'd be happy with 120bhp to be honest.
21-09-2013, 04:58 PM
Had a run up to Whitehaven to get some Rainsport 2s fitted at Camskill, £166 for 4 which I was chuffed with, would've been rude not to have a blast over the Kirkstone Pass and along the shore of Ullswater...
21-09-2013, 05:03 PM
Rainsport fwends!
21-09-2013, 05:17 PM
(This post was last modified: 21-09-2013, 05:17 PM by devils_fuel.)
![]() the smokey old bus that sounds like a tractor...
21-09-2013, 07:12 PM
It started chucking it down (standard Cumbria) so good chance to test them out, amazing wet grip, can actually pull out of junctions quickly without just spinning up
21-09-2013, 08:47 PM
(21-09-2013, 07:12 PM)THE_Liam Wrote: It started chucking it down (standard Cumbria) so good chance to test them out, amazing wet grip, can actually pull out of junctions quickly without just spinning up I've had them since last October and rate them well in the wet, great for stopping as well in a non-abs car
21-09-2013, 10:11 PM
(21-09-2013, 08:47 PM)devils_fuel Wrote:(21-09-2013, 07:12 PM)THE_Liam Wrote: It started chucking it down (standard Cumbria) so good chance to test them out, amazing wet grip, can actually pull out of junctions quickly without just spinning up What they like for wear? Long lasting?
21-09-2013, 10:39 PM
(21-09-2013, 10:11 PM)THE_Liam Wrote:(21-09-2013, 08:47 PM)devils_fuel Wrote:(21-09-2013, 07:12 PM)THE_Liam Wrote: It started chucking it down (standard Cumbria) so good chance to test them out, amazing wet grip, can actually pull out of junctions quickly without just spinning up The sidewalls wear terribly quickly!
21-09-2013, 10:46 PM
(21-09-2013, 10:39 PM)vlj Wrote:(21-09-2013, 10:11 PM)THE_Liam Wrote:(21-09-2013, 08:47 PM)devils_fuel Wrote: I've had them since last October and rate them well in the wet, great for stopping as well in a non-abs car Sidewalls?!?!
21-09-2013, 10:51 PM
Yep, soft as shit sidewalls! Got them on the 6, renowned for it tbh.
21-09-2013, 11:29 PM
(21-09-2013, 10:51 PM)Carlos182 Wrote: Yep, soft as shit sidewalls! Got them on the 6, renowned for it tbh. Just gotta burn the rubber before the walls go then
21-09-2013, 11:49 PM
That explains the uber smooth ride, it's like driving a car with proper rear suspension now
22-09-2013, 08:41 AM
(21-09-2013, 11:49 PM)THE_Liam Wrote: That explains the uber smooth ride, it's like driving a car with proper rear suspension now They are more comfortable and very little road noise ![]() the smokey old bus that sounds like a tractor...
22-09-2013, 02:07 PM
I'm bored of the soft sidewalls on mine tbh, they'll be staying on the winter wheels next summer!
![]() Diablo Meridian HDi - 125bhp - 73.0MPG - Halfords Wheels
22-09-2013, 02:13 PM
If anyone finds a tyre that has the wet grip of rainsports, but without the noise and ridiculous sidewalls that'd be useful to know!!
I can't fault their wet grip at all but the sidewalls do my head in, as does the road noise.
22-09-2013, 03:20 PM
22-09-2013, 04:49 PM
bit of catch up here...
saying about the hunting on veg.....two suggestions, change fuel filter much more often...IE 2000miles max. you can get them super cheap so its not expensive. try the penny trick...as soon as head is getting warm...30seconds or so...the oil is beginning to heat and stays that way at all temps Wishes for more power...
22-09-2013, 05:53 PM
(22-09-2013, 05:08 PM)Piggy Wrote: bit of catch up here... That's about how often I change my fuel filter and it's no different on a fresh one, but what's this penny trick?
22-09-2013, 06:01 PM
(22-09-2013, 05:53 PM)THE_Liam Wrote: Nah, charged me £30 for fitting and balancing so £163 all in. Pretty good I thought. That's what I paid for my set fitted but 105/55/15's, good price ![]() the smokey old bus that sounds like a tractor...
22-09-2013, 06:02 PM
googlenium it.
basically making the fuel under fuel filter always pass through the heater section Wishes for more power...
24-09-2013, 10:45 PM
(22-09-2013, 06:02 PM)Piggy Wrote: googlenium it. there's an easier way of doing it, take it to bits and it's pretty obvious, i'm not sure why people mess about with pennies but hey . .
25-09-2013, 06:22 AM
I've done it loads of times on mine and others cars...its quite simple.
I also normally get a dremel out and make sure the holes have decent flow coz its quite restrictive. you also need to make sure your glowies are top notch now its getting chilly overnight. Leak off pipes too can cause issues. Wishes for more power...
30-12-2013, 07:27 PM
Well, been doing a bit of pondering over what I'm doing with this. Haven't done anything new to it at all, just driving it and generally abusing it, never misses a beat really. Clocks died, but got a set for a tenner off danny2009 and it's good as new, needs some serious work though, wishbones are absolutely f*cked, droplinks are knocking, tracking is out, engine mounts are f*cked, rear dampers are f*cked, brake light bulbs keep going randomly, heated rear window is dead, passenger window is dead, central locking is dead, speakers are crackling like f*ck and the aux belt sounds like a stabbed squirrel but she still won't die, really not sure whether to keep it and sort the mountain of faults out or just break it and get another. It's also still running 100% pure GM soya oil, never fails to start and doesn't really feel down on power or anything, although it hunts like an absolute bastard for the first 5 minutes on a morning and pumps out clouds of black/blue smoke, as folk will remember from the morning after the xmas meet
![]() Quick photo with Sam's epic 305...
30-12-2013, 07:51 PM
All that stuff just sounds standard wear and tear. Get it sorted out and it'll be all good again. You won't get motoring any cheaper than that and a new car may still be fecked.
30-12-2013, 08:28 PM
(This post was last modified: 30-12-2013, 08:38 PM by devils_fuel.)
Sound like some of the issues with my car Liam...drive it on son
30-12-2013, 08:36 PM
Also sounds a lot like my car!
I also echo the cries of "stick with it", better the devil you know! That's how I see it anyway, hence I've not chopped mine in yet.
| Project T Phase 2.5 Diablo DTurbo... | Kwik | 90 | 79,876 |
24-02-2021, 11:51 PM Last Post: stevieg |
| Project Crap - Fix or Break?? | Toms306 | 37 | 21,011 |
20-10-2015, 08:24 PM Last Post: Toms306 |
| Phase 2 Diablo Red Dturbo | Richieboi13 | 0 | 1,982 |
10-07-2014, 02:57 AM Last Post: Richieboi13 |
