27-02-2012, 04:44 PM
The TD04
![[Image: Td04readytofit.jpg]](http://i1235.photobucket.com/albums/ff436/studturbo/Td04readytofit.jpg)
![[Image: mintsig.jpg]](http://i1235.photobucket.com/albums/ff436/studturbo/mintsig.jpg)
STAGE2 XUD DEAD ATM ENGINE REBUILD
GARRET T2-BOSCH PUMP-GROUNDED LDA PIN-GOV MOD-FMIC-STRAIT THRU STAINLESS EXHAUST SYSTEM
COMING SOON TD04
My 5Door Blaze DTurbo Project
The TD04
![]() STAGE2 XUD DEAD ATM ENGINE REBUILD GARRET T2-BOSCH PUMP-GROUNDED LDA PIN-GOV MOD-FMIC-STRAIT THRU STAINLESS EXHAUST SYSTEM COMING SOON TD04
01-03-2012, 04:01 PM
Well got my loom sorted it was a dodgy earth so she all good now just got to put her back together now
Then her mot on the 3rd :o ![]() STAGE2 XUD DEAD ATM ENGINE REBUILD GARRET T2-BOSCH PUMP-GROUNDED LDA PIN-GOV MOD-FMIC-STRAIT THRU STAINLESS EXHAUST SYSTEM COMING SOON TD04
01-03-2012, 04:10 PM
Good luck with the MOT mate
01-03-2012, 04:24 PM
Cheers dan am gunner need it with all stuff av got to sort haha
05-03-2012, 06:45 PM
Well she starts and that and sounds good just need to do my cv boots as there split then i can book her in for test but cv boots bin a bitch anyone know how to get driveshafts apart to make it easyer ?
05-03-2012, 06:51 PM
Theres a like circlip thing in the joint.... you'll have to clean away some of the grease and stick some "opposite" pliers in there haha
05-03-2012, 06:58 PM
good mate. is it a sweet engine
Venetian XUD ph2 heaven
Ph3 perv cab heaven Black ph1 XUD died Moonstone hdi stage 2
05-03-2012, 06:59 PM
Oh really is there gunner be a bitch to get it back in tho
05-03-2012, 07:00 PM
Yeah pal its sweet was abit white smokey when i started it but timing on pump was out sorted that now she sound sweet
05-03-2012, 07:01 PM
goood whens the test drive
05-03-2012, 07:02 PM
when av put it all back together haha couple of days i want it to be spot on for test
07-03-2012, 05:25 PM
Feel abit down graded i have put the tmic on for the mot but other than that she is all up and running now just got my fans to wire up then she ready for test
anyone good a good way i can wire my fans up to a switch ? ![]() STAGE2 XUD DEAD ATM ENGINE REBUILD GARRET T2-BOSCH PUMP-GROUNDED LDA PIN-GOV MOD-FMIC-STRAIT THRU STAINLESS EXHAUST SYSTEM COMING SOON TD04
07-03-2012, 05:40 PM
All so can anyone tell me what type of cable will i need to put my bat in boot ?
thanks ![]() STAGE2 XUD DEAD ATM ENGINE REBUILD GARRET T2-BOSCH PUMP-GROUNDED LDA PIN-GOV MOD-FMIC-STRAIT THRU STAINLESS EXHAUST SYSTEM COMING SOON TD04
07-03-2012, 10:37 PM
f*cking big cable
hock:Edit: Thats a technical term aswell
09-03-2012, 06:09 AM
Going to get a wiring loom out of a bmw 3 series thay got battery in boot
09-03-2012, 12:43 PM
For the battery in boot declantg ?
09-03-2012, 12:45 PM
Ok pal will do when i get all stuff from scrapyard
09-03-2012, 01:04 PM
need to sort my knocking noise out
09-03-2012, 01:05 PM
09-03-2012, 06:04 PM
Sorted the knocking noise the timing was out by 3 teeth
09-03-2012, 06:36 PM
studturbo Wrote:Going to get a wiring loom out of a bmw 3 series thay got battery in bootyou dont need to do that just go get something like 0awg wire and run it from your origional +ve connection on the battery to the boot, you could get a battery terminal and just connect the two similar to the one in this pic... the red wire being the new one which will route to the boot (or wherever the battery is going to be ![]() then the negative you ground to the body then upgrade earth straps as for the battery in the boot, ground that to the body too hence the need for upgraded earth straps
12-03-2012, 05:28 PM
Pushed my battery back abit so its out of way of my intercooler pipes
14-03-2012, 12:05 PM
Failed the mot on brake hoses and hand brake soon sort that out
14-03-2012, 06:03 PM
The coilovers are now on and it sits nice will get picture up soon
15-03-2012, 03:47 PM
Any pictures today stu?
15-03-2012, 04:18 PM
Glad u like em mate, get some pics up
Vehicle repair and servicing in the midlands pm for detailsĀ
Current cars Subaru Impreza 2.0d - Daily 306 1.8 - track whore soon to be GTI6
15-03-2012, 04:25 PM
Get those belt covers back on, I know from experience not to run with them off...
It SHAGS the belt. I had bits of belt flying everywhere for ages because I ran without the pump one... |
| Project T Phase 2.5 Diablo DTurbo... | Kwik | 90 | 82,355 |
24-02-2021, 11:51 PM Last Post: stevieg |
Another DTurbo Project | Hobo Ash | 11 | 11,336 |
04-10-2017, 07:32 AM Last Post: TommiePuglet |
| Blue 306 dturbo s project | Logue1996 | 13 | 10,120 |
14-08-2017, 11:58 PM Last Post: Logue1996 |
