karl1989 black ph1 boost bus roof opinions
What happened with the headgasket?
[Image: mcetg0.png]
Radiator doesn't want to bleed up. Going to have another go after work. What is this worth to people
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Brand new thermostat dodgy, 2nd one out of the spare block still pressurised so took the thing out. Temps at 70 witch is good but should the top hose still get quit hard?
Ph3 perv cab heaven
Black ph1 XUD died
Sounds like similar problem that I've got. I'm going to try a thermostat but I think its more likely HG
Should get firm but not rock hard lad are heaters red hot?
Team Doesn't own a 306
The more higher temps get the warmer the heaters. Not loosing water and no oil in water
Also when I hit boost it drops like 3 psi in 3rd-4th
Ph3 perv cab heaven
Black ph1 XUD died
Not updated for a while
[attachment=12280]
[attachment=12281]
[attachment=12282]
[attachment=12283]
[attachment=12284]
[attachment=12285]
[attachment=12286]
Ph3 perv cab heaven
Black ph1 XUD died
  Karl1989 moonstone HDI karl1989 85 34,910 09-04-2014, 09:18 AM
Last Post: karl1989
  karl1989 black ph1 boost bus karl1989 3 2,891 22-08-2013, 02:57 PM
Last Post: karl1989
